mpc
74 -
Everything posted by mpc
At about 8:20 in this video he pulls the tool out of the heat and presses it into a white powder (Borax?) before quenching. Can someone tell me what is going on here?
Added for posterity? I've already posted these on here in another thread but I didn't see them here.
This is at a little antique store in a small Idaho town. It’s at a crossroads between the interstate and Sun Valley, ID so they get the wealthy/bored tourist traffic. The seller has dozens of rusty sheet metal art pieces. I’m sure there are dozens of condos in Sun Valley with a Sasquatch or two. I went back today. The screw looked good. I offered $150 but they said they only had authority to go down to $200. The vise (and all other stuff in the photo) don’t belong to the store owner. They’re from a guy who rents space there. From the response I got, I think the guy probably paid more than $150 for it.
Stumbled upon this today. 5” jaws. $250. I was still in my clothes from court so I didn’t get a chance to take a good look. I think I just found me a new vise.
Thanks for the replies folks! For those who commented on the idea for this use of RR spikes, this wasn’t my original idea. My daughter saw it on Pinterest. I don’t know who came up with the original idea but it’s really clever.
So... My kid saw this online and said she wanted one. It took me a while, but I finally was able to make something I didn’t hate. Question: How would you go about cleaning this thing up? There is weld splatter, forge scale, and all sorts of other “dirty” stuff that probably doesn’t belong in a little girls bedroom or on something kids will handle. I don’t have a sand blasting cabinet and the idea of hand sanding or going over all of the little parts on this with a dremmel does not sound happy. Can you sand blast without a cabinet?
Wait... What? Is that possible? I just kind of assumed it was “done” because... I don’t know why... because it was... cold?
I’m more than a little depressed. This was 5 layers. 1084/15n20/1084/15n20/1084 My next project is going to be one of those knives the samurai used to disembowel themselves.
He’s looking to buy because he doesn’t have the time to build. He’s looking at the Chiliforge and Majestic 3 burner forges. Is the Chiliforge worth 2x the price?
In this way Blacksmithing is like my profession and it drives me crazy. You can’t really learn how to get it right by reading a book or watching YouTube, you’ve got to spend some time with people who know what they’re doing and watch them do it to get that “feel” for how it’s done.
I knew I left something out. This time I did use flux. Just regular Borax out of the box. I cleaned the steel & ground off any scale. Then I tack welded the layers together. Then I stuck it in Kerosene (to keep it from oxidizing while I got the forge ready).Then I got the forge up to temperature and putting out a good reducing flame. Then I put the stack in the forge for a while. Then I pulled the stack out and quickly applied borax to the edges. Then back in the forge until the stack was the same color as the rest of the forge. Then another few minutes longer just to be sure. Out of the forge and on to the anvil for some firm, straight blows (so it didn’t shift). Then - quick scoop of flux and back in the forge.
Propane, 3 burner in an old tank (freon I think). I’m running between 10 & 15 PSI. I’m thinking I need to rip out the old lining and do it again. It wasn’t in great shape when I got the forge and it’s thin in some spots.
Another attempt, another failure (mostly). 15n20 & 1084, I got the surfaces CLEAN, & I let it soak at temp for a LONG time. I started with 10 layers but looking at it closely after I’ve beat it around a while, it looks like there were only 3 or 4 lines that don’t go away no matter how far I grind. I assume that means that some of my welds stuck. I guess that’s an improvement. The learning process is frustrating for a weekend warrior. It takes so long to fail and then you don’t get to try again for a week or two.
I’m a little bummed. I had a failed attempt at a “damascus” billet yesterday and I can’t figure out what went wrong. Here was the process. I cut several pieces of good steel (1084 and 15n20 from AKS) down to about 1 x 3. I cleaned them them with acetone, gave them a quick rough up on the belt grinder, cleaned them again with acetone, then stacked them and then welded the stack to keep everything in place. I stuck the billet in some kerosene (overnight) and then went straight from the kerosene to my forge (the next day). According to my thermocouple probe, the forge was over 2200° when I put the steel in and I kept it there for 10 or so minutes (until everything was all the same color). I took it from the forge to the anvil, gave it several firm smacks with the hammer and then back into the forge. I repeated the process a few times and then started drawing it out. It looked like it was welding but later, after I let it cool and did a little grinding, it became clear that the layers didn’t stick. Everything is still in place but there are clear lines between the layers and the top layer comes up when you grind it at an angle. I can’t think of where I went wrong.
This may be a stupid/rookie question but why do people mix in things like coal dust and graphite?
The casters aren’t going to touch the ground unless it is tipped back. I’d love to do a big plywood base but I’m really short on space. Everything I have (forge, anvil, grinder, band saw, tools, drill press, work table...) all has to fit into about 2/3 of my 3rd car garage. On this guy, the base is 1/2” thick and heavy. I’ll wheel it into place and then throw a couple of sand bags I have laying around for this kind of thing (dead weight) across the plate to make sure it doesn’t walk around.
Well, the base is almost done (I’m going to put casters on it). I had to forge a new bracket to hold it in place. That was entertaining and educational. I just need to make a spring and I’m done
This is one of those answers that, upon hearing it, you immediately realize is correct and can’t believe it didn’t occur to you before. Is it just me, or does anybody else get a calm feeling, like the universe makes sense, when the answer to a question is absolutely brilliant in its simplicity.
I have no idea what I’m looking to buy here. Is this just a chunk of actual bees wax or am I looking for a product made from beeswax? I need to make some tools for the hardy hole in my anvil. Before I go banging a hot piece of metal into that hole, I figured I’d check to see what the YouTube had to say about it and, sure enough, it is recommended that you put some lube in there to keep the thing from becoming a permanent part of the anvil. So what should I be looking for here? In light of the current shut down, are there options I might have on hand?
First weld ever (not really, I welded once in 7th grade but I’m not counting it). It’s terrible, it’s awful, but I finally got off my butt and tried. About 3 hours before the Governor decided to close the state for 21 days, I was driving past HF, and decided to stop and buy their cheap welder, so I can teach myself to weld. For fun I was just making sloppy lines (very sloppy) and then wanted to see if I could make 2 pieces stick together. They are stuck and they have not yet fallen apart! It may not be a big deal to you but after almost a decade of school and countless years of intellectual navel gazing it is very nice to be doing things rather than thinking things.
Any tips on forging a new spring? I need to forge a new mounting bracket. I figured I’d just use some 3/8 mild steel I have sitting around for that. Then, I’ve got a big ol’ coil spring in the garage. I was thinking I’d cut off a bit, draw it out to something flat and just do something that will be held in place by the bracket (like the photo). Do I need to use “spring” steel? Do I need to heat treat it?
Plot twist: I am out of degreaser! The Mrs (healthcare provider) says it’s not a good enough excuse to run to the store. Now I have to find something around the house to use to clean it. Coronavirus! Also... I stuck my finger in the screw box and was surprised to find that there are only about 2” of thread in there. I was expecting it to be much longer.
I spent my first day of “social distancing” in the garage working on the new vise. I had to cut it away from the RR track. Then I had to cut away the old bracket (because it had been welded into a large glob of metal). They had welded a coil spring around the screw mechanism and that took some time to finally cut away but now I’m down to just the parts. I took pics of all the markings I could find. Next up, I might degrease and re-grease the screw. Maybe clean up the jaws a little. I need to forge a spring and a new bracket. Then I’ll work on figuring out a base. Any other suggestions from those of you who have done this before?
I read a similar article. I think you are hitting on the big point here. The issue isn’t how deadly COVID-19 is, it’s how quickly it can overwhelm our medical system. The classic example of St. Louis Vs. Philly (see attached) is very helpful. If you use social distancing you can “flatten” the spikes and keep the hospitals from getting swamped. Then, by having adequate facilities we can make things even less deadly. The media hype has done two very bad things: 1- Put people into panic mode. 2- Created a “crying wolf” feeling in people. The panic one is obvious, panic makes basically everything worse. The other side of the coin is a little more complicated. When the media loses credibility like ours has, people start asking themselves who stands to profit from each story and hype train that comes along. Then, when something like this happens you get people who believe that there is some nefarious plot behind everything. As a result, people ignore good advice.
