Damion78
132 -
Everything posted by Damion78
Thank you it has been a fun project. I started with a 1/2 hp motor, moved up to 1hp both bogged down. I am now in the process of fitting a 6000 rpm 9in angle grinder motor to it. I have had it hooked up but need to step pulley it down it's a little to much but it really takes the metal off and shows no signs of bogging down at all. I'll likely do another video when I'm through.
Thought I would share my DYS 2x72. 2x72 scrap grinder.: https://youtu.be/pjqzM5yGMWI.Table saw turned belt grinder.: https://youtu.be/xWobnS-f48k .Table saw 2x72 belt grinder belt tension.: https://youtu.be/lkRZBqZVxcg
Hey Joel I've just recently picked up two 4x6 bandsaws one new from harbor freight and another older model I bought used. So far they are treating me great. They took a bit of adjusting but that really goes with any tool. I've been cutting 2" hardened steel and steel tubing without any trouble. They are not the fastest but they are faster than a hand hack saw and they are cutting square. I let them do their thing while I work on other things. I have added better wheels and have plans to mod the vise. In my opinion they are a good investment.
Area specific as in availability within the area will effect value.
My 35 gallon steel drum slack tub froze over this winter I just threw a chunk of hot scrap on it when I needed it. This was not a problem until the seem blew out of the bottom from the expanding ice during an unexpected deep freeze.
Thank you, I think it probably came to around $ 70. The steel I had picked up just to have the forks for whatever but paid around 30 for what I used, paid a few bucks for the screw, spent 30 or so on the hole saws I used to cut the holes. Then factor in the welding rods I had and the flap disc I used. Cutting the holes was the hardest part, I used a hole saw and a drill so if you can find a better way that would help. I also used files to elongate the hole on the moving jaw.
Thank you.The screw is from an old carpenters vice I believe, I looked at some screw jacks also and they would have worked well I think but I picked this one up for a few bucks so I went with it instead. I had thought of using two forks at first and grabbed them because my idea was to build one like a wooden carpenters vice but went with this because I wanted to save the material for another project. I've found I really only use the rail anvil for light small work and I think I will still be able to utilize it in some aspects. All in all I am really happy with how it turned out. I may still need to do some dressing on the face but that can be done if and when I find a need to.
Thanks a ton for all the pointers. The hinge pin is a half inch and It will be replaced with an appropriate bolt, I just didn't have one on hand when I was working things out .
A wheel would be nice. I have a small one on my band saw vice and I like it better than the other one I have with a handle.
Putting a handle on is definitely on my list of things to do, it twists freely but that would wear a guy out and it would be hard to get it real tight. The jaws do come together flush. I haven't done anything to the face yet because I wanted to see how things would work, I'll look into dressing them. If I understand correctly the idea would be to have them squared at around half an inch or inch for a common stock size and a radius to give more contact to variable sizes?
Thank you, it was a what do I have project so I went with the dumbbell screw, I believe it is 3tpi seems to work ok but I have plans on looking for a better one.
So I haven't had any luck finding a post vise and I've broken one of my bench vises so I'm building my own here it is so far. It weighs around 120lbs, stands 38 inches high, and has 5" jaws.
kohlswa anvil is it worth it
Damion78 replied to Damion78's topic in Anvils, Swage Blocks, and Mandrels
I am honestly stuck on the issue. I would really like to own a "real" anvil but my railroad tracks anvil and my forklift tine anvil work pretty good so far. There are a lot of other tools I could get for $500. This is just a hobby for me I may just wait but then I may not. -
I think in my mind the flatter is more accurate than swinging a hammer. You are able to isolate high points in the work and get a more uniform surface.
Thank you, the eye is a little off but the wedge makes it look more so.
It is just a want, I don't need it. I've wanted one for awhile now and there really just are not any around here. There was a really nice 200 Emerson around for 800 just recently but of course I didn't have the money at the time. A few 100 pounders here and there for around 400 but I'd really like 150 or up. -
Thanks for the response. I've been toying with the idea of picking it up. It's a few hours away so I wanted to get some opinions on it before I took the drive to go see it. It's the closest one I've really been interested in. -
Hey all just wondering if this anvil is worth the asking price of $550, it's 176lbs
Thanks a lot it was tons of fun to make. I used a chunk of the axle from the rear end off my bronco. I had to upset it quite a bit to get the face as large as I needed and it took quite a bit of beating to flatten out the peen. I was more methodical about my hammer strokes on this one and did very minimal grinding.
This is my second attempt at a cobbler hammer that I made for a friend that does leather work. It weighs in at 27 oz he wanted 24 but I over shot a bit because I wanted to give him weight to dress it.
The rods my buddies, he is always ready to fish.
Thank you, it was pretty fun to make and simple enough. It was the first time I have done a handle like that, and I learned a few things for next time.
This is a flatter that I made from a large rusty bolt that was given to me.
