274 -
Everything posted by angiolino
i build a metal arm gin pole to be installed at the rear of an agriculturar machine for uses as a crane what material do you suggest to use that tecnique h 12 feet p 2 ton
hello I should carry a rake or a tool to smooth and clean the sand of the beaches from waste and stones debris carried by storm surges would advice thanks
Ciao, io Così se METTERE La Discussione Nel forum giusto, tuttavia Expore la Domanda: Dovrei Costruire Una drawbarr rigida per il traino di camion o coacher in Fallimento, Come una grande Dimensione dovrebbe attacched Rudden avanti e indietro dei Veicoli Che Si Può aiutare me noiSei le Dimensioni del materiale: 2,50 metri Peso / 3 della metropolitana per TIRARE 12 tonnellata tanks
iron roof against the house wall made bolted or welded
angiolino replied to angiolino's topic in Problem Solving
thank you for your valuable record -
Sorry guys but I do not speak English and I have difficulties to insert pictures and drawings I would need tips and sorry if I postat 2 messages sequentially aspect grazi tips for your patience and your precious time is a patio sun to achieve iron frame transparent cover polycarbonate 16 mm -
hello I have to build an outdoor canopy type patio that serves as protection for the front door and canopy for the car measures sono.lunghezza L = 15 feet, width = 10 feet, height = 11.5 feet in iron, from a i want to side with iron plates bolted to the wall on the other side i want to support the joists to a girder resting on two iron pillars type portal that advice you can give me what material to use that section with aspect information and suggestions hello -
hello we have to realize for a house in the countryside a shed or pergola or patio to be fixed to the wall and then place an iron portal measurements are 20 feet long high 11 ffet larga13 feet iron one hand resting and hooked to the wall of the house from 'backed up to a portal formed by two pillars iron uprights and a beam iron might help size the various parts and materials required have a drill welding and grinding machine thanks
thanks for your helpuful suggestion I will make certainly treasure
hello I do not know if you can help we would like to make a manual winch or a capstan winch to haul and tow boats and small boats maximum length of 20 feet wood could you help me to design it and make it look simple materials with tips
thanks for the valuable advice I will treasure it, doubt it was just the choice of material for the steely blade to prevent denting and wear thanks again
hello guys sorry to disturb you, I do not know if this topic is relevant to this area of the forum, however, expose: For personal reasons I should build a hand tool that they use the fire department to clean the areas sogette to fires is a hoe rake I need for my wasteland as they could burst fire could you help me to realize that tools and materials method you advise me to use materials that can be recycled to the blade if I use sheet steel joint venture to use it a little time to dent it and make it unusable I would do a lightweight and sturdy manegevole at the same time, thanks to the next aspect of suggestions I invite you to respond
hello gentlemen users of the forum, today I beg to ask your technical advice because I would like to solve a problem of domestic security. I should build and install an old country house in a security door to prevent access to malentenzionati. Unfortunately, the size of the port are not standard so they are forced to realize it in the traditional way, I need advice drawings or photos, affinche this port does not look like the door of a prison I would like to do it in sections internally and externally by steel plates planks of wood type medieval castle you could give me suggestions on materials hinges bolts locks wood profiles for door and window frames and methods of construction and installation thanks to await the next news https://www.youtube.com/watch?v=ly_BzgHS08E
New welding machine (was a very long complex title)
angiolino replied to angiolino's topic in Welding Equipment
okay I will let you know next week I begin to use it I have to weld beams 160 mm, I made a good buy? I took basic electrodes of 2.5 mm and 3.5 mm, the welding machine is single phase. the current contract has a power of 3.5 kw, do you think it is sufficient to achieve good soldering resistant? thanks to the next -
help support portal design loft iron
angiolino replied to angiolino's topic in Welding/Fab General Discussion
thanks for the solidarity and the information sorry for the bad English, if some user had more information I invite him to intervene with hello -
hello gentlemen users of this prestigious forum, finally for my birthday, I bought a new welder inverter three phase 220 v this is an MMA Welding Machine max. 180 A | PFC SOON Inverter welding with coated electrodes. These models are extremely robust and reliable. Particularly simple to use thanks to features Hot start, Arc force and anti bonding. Weld rutile, basic, stainless and special electrodes. They can also be used for TIG welding with scratch striking. They have to set the DIGITAL DISPLAY, the socket for remote control and VRD function which makes it suitable for working in hazardous environments. think someone has made a good choice among you use it as it is,? that recommendations and opinions you can give me? I await answers thanks excuse my insistence and petulance
prejudice should make a loft for a local high 480 yards, for that purpose by a 180-beam ipe 3 meters long and supported by 2 pillars boxed 80x 80 x 3 mm, I'm creating a portal to support lean spars to which I will have to support the platform, the platform should have a capacity of 400 kg / m / q what can you tell me about what advice can you give me? I will have to use tricks that will not collapse Directory to all and achieve a robust, monolithic mathematical formulas that I have to apply? thanks to those who will want to help me look forward to the next hello tips and experiences
Virtual Assistant for project gantry crane 2 tons
thanks for your valuable advice lighthouse treasure it, for dimensionarte perforated plates fixation cross struts that formula and criteria to use thanks to those who will want to respond -
thank you for your testimony I'll think I have advised the above multiprocess say they are like the food processor you use them 10 times and then break them remains without a car is a big investment thanks for your valuable contribution and for your advice if other had more info I invite them to intervene with the next
lathes are 2 one is 2.5 meters long and weighs 2 tons and is all cast iron and the other is 4.5 meters long is a unique fusion of cast iron bench is that the tank that the uprights of the base weight from 3 to 4 tons, I have a simple crane mobile crane classic 60 years old with manual winch and pulley made of beams ua gooseneck you imagine a binda 6 tons and a lot of good will and a lot of elbow grease, if the Egyptians built the pyramids I hope no machinery to move and place these machines as soon as possible in the other thread that's why I wanted to build the gantry crane for use as a crane anyway thanks for your precious words and advice I treasure the next beacon please send illustrative photos thanks
I'm sorry if you expect so much from you attach photos of the machines mentioned translating from Italian to English, the meaning changes a picture is worth a thousand words, however, I had suggested the miller the fronius the Lincon and hobart are not convinced of the esab and saf fo della cea italiana you who have experience and opinion?
hello guys sorry if I am asking for your illustrious opinion. I would buy for my small workshop in a multi-process welding inverter synergic new generation. Of those that are running tig mig mag welding electrode conventional plasma cutting which brand do you recommend? a good efficient and reliable maybe cheap? thanks to those who will take you recommend course of the rising sun but not brands internationally renowned brands prestigious reliable with good performance and fewer defects and certified thanks again
thank you for your intervention and your precious words lighthouse treasure of your experiences commercially sell roller skates what do you think? used hoists for lifting special homemade or other types of dellebinde jack or forklift sorry if I insist but any witness or experience may be useful to me I have to move a lathe 4 meters long heavy 3000kg and other machine I have is a few tools and some do not I will have to buy potendoli build them myself thanks to the infinite patience and your valuable time
