Jack Evers
325 -
Everything posted by Jack Evers
CounterWeight Anvil?
Jack Evers replied to Cbennett0811's topic in Anvils, Swage Blocks, and Mandrels
I got the EBAY SITE to open by copying and pasteing to my browser. Seller doesn't seem to know a lot - says there's a round hole and a square hole in it. Gives dimensions and says it weighs about 117 pounds. Seems right for the dimensions. Stand and hardy tool included. There's a second picture from the top. Edges a bit chewed toward the horn end but not bad. Someone back east needs to comment on prices, but I'd say $2 to $3 a pound wouldn't be all that bad. Presently a $65 bid. Won't ship, must be picked up on site. That should eliminate a bunch of potential buyers. -
191# Soderfors Thoughts
Jack Evers replied to Wesley Chambers's topic in Anvils, Swage Blocks, and Mandrels
I find it quite satisfying to work on an anvil that I restored. -
To start, here's a link to an anvil restoration article. If you google Rob Gunther - anvil restoration, you'll find more. http://www.anvilmag.com/smith/anvilres.htm I wasn't quite that scientific - rather than hard facing rod, I just used a 7018 rod and guestimated at the preheat temperature. Hot enough to sizzle water then a bit more heat. It worked!! Since I'm not the best at controlling my weld puddle, I clamped a copper "chill" strip (flattened copper tubing works fine for this)along the edge that I was building up to contain my puddle. After the face was built up and ground down, I laid the anvil on it's side, moved the chill strip to the now vertical restored face and built up and ground down the side the same way. Since I believe your anvil is solid cast steel rather than having a welded on steel face, you don't need to wory about dissimilarity between the base and the plate. I didn't do any post heat treatment, but a Vulcan Anvil isn't a cadillac anyway and it's worked for a long time. I had one minor rebuild when I had my son striking for me in a draft shoe contest and he missed with an eight pound sledge and knocked a chunk off one edge. Jack -
Here's a link to a previous post of mine. Post #6 This anvil had edges as bad as yours, although not so bowl shaped. I preheated by guestimate and built up the edges with 7018 rod. That was 20 years ago. As a farrier also, I know why you need at least some conveniently located square edge. I draw clips off the heel on this one (very thick heavy heel. I can give more rebuilding detail if you want. -
anvil horn ''left or right''
Jack Evers replied to Hofi's topic in Anvils, Swage Blocks, and Mandrels
OK, I'll be the real maverick (and farrier), my 280 pound shop anvil faces right, my 85 pound truck anvil faces left. The heel on the small anvil is so thin and light as to be nearly useless and I do most of my work on the horn end. The clip horn is also in the traditional place. The big one has a solid heel, no clip horn and straight sides. The easiest place to draw clips is off the heel so I set the heel to the left. -
It's been a while since I made the calculations, but the theoretical temp for combustion of propane is around 2400 degrees F. Depending on the lineing and air mix you should expect 2300 plus or minus. As I say, I'm trying to recall, so I don't mind being corrected.
I have a horseshoeing client who used to want shoes hardened. When using SQ, I just made sure it was plenty hot - often at yellow - and never had problems with it not getting hard. On a very hot shoe, it doesn't seem to really breakdown the vapor layer until it cools somewhat, but they still get hard.
Glad to see you're back, Frosty. Jack
You might be interested. Awesome Grave Stone - The Farrier & Hoofcare Resource Center Forums
Very, very sorry to hear of things like this.
Will copper penny ruin a forge weld?
Jack Evers replied to David Einhorn's topic in Blacksmithing, General Discussion
In a farrier contest, I once beat one of the best on a forge welded barshoe when he missed his weld -- he blamed the fact that he'd been copper brazing in the forge (gas forge) Don't know if it was a fact, but this guy believes it since he's one to look for solutions, not excuses. Incidentally 1981 and before pennies are copper. In a pinch, I've used them to braze with. -
I've generally estimated all bio mass fuel at around 7000 BTU/lb - born out by the table in post 2. Something as light as dried horse manure wouldn't carry a lot of energy on a volume basis.
Frank, Back in the 70's (about when I first saw you work) I watched Bruce Daniels punch a hammer head. He talked about sticking the punch and was sprinkling some coal fines into the hole ahead of the punch to prevent sticking. Have you seen or done anything like this?
Still Around, found my first anvil, again
Jack Evers replied to Jack Evers's topic in Anvils, Swage Blocks, and Mandrels
Right, after all these years it was hard to know it was really the one I built -- just something about it said it had been mine. -
Finally got by to take pictures. Crude, but it gave me good service and still gets used. Today the stand would be a lot shorter and a lot heavier. I'd gone to the junkyard to look for RR rail, but that piece of steel was right by the door and it looked good to me. -
Friend of mine said his only wound in Nam was working in a ship boiler room. Got too close to a guy with a hammer, got hit in the head on the back swing. Bloody cut, not much else, but the guy that hit him saw the blood, fainted and fell into a bunch of pipe doing himself serious injury. Glad your son didn't do something like that.
Loved seeing it was still being used. -
I had an interesting experience today. Helping a friend with a project and needed to drill some holes. I asked if he had a drill press, He said his neighbor did so we went over there. I needed to straighten someting also and asked the neighbor if he had an anvil or at least something to beat on. He said that there was an anvil in the back corner. I went back and there was my first anvil. I built it from a piece of 3" by 4" steel back in the 60's, gave it to a friend in the 70's. The friend has moved away, but there it was on the stand I had built from metal fence posts, rebar and angle iron. I'll try to go back and get pictures.
vulcan anvil?
Jack Evers replied to coldcashandcolderhearts's topic in Anvils, Swage Blocks, and Mandrels
Thanks Ken, Make that 5/8ths. (0.625). It would have been a good trick.By the way mine is stamped 25 (250 pounds) and came in about 280 on the bathroom scale, a bit bigger than the OP's. -
vulcan anvil?
My plate is about 9/16ths - likely was 3/8 new, before some edge wear and polishing. -
vulcan anvil?
That didn't work very well so here's a repost of the picture -
vulcan anvil?
As far as a pritchel hole, here's a link to my Vulcan, notice the groove about an inch behind the step. As a farrier, I punch many nail holes - 6 or 8 per shoe - and that groove is easier to locate than the pritchel hole. I cut it with an angle grinder in about 10 minutes. http://www.iforgeiron.com/forum/attachments/f83/14269d1242779152t-arm-hammer-anvil-weld-img_0256.jpg -
Yes, they are. I've not used one, but being relatively close to Cliff's business, I see a number being used and have not heard of any problems and I suspect the heel bending cams would not last long on inferior construction since they're often used to cold shape a shoe.
Gee Frosty, you posted while I was trying to find Cliff's Website Yep that's a Cliff Carroll Anvil - probably his popular 70 pounder for farriers - nice size to move around., very much still in business. Cliff Carroll's Horseshoers Supplies, Inc.
Here's a thread that shows it - about post 18. Suspect jevaccaro is using a similar technique . http://www.iforgeiron.com/forum/f7/rasp-spurs-9805/index2.html Straight shank, dropped shank, raised (or gooseneck shank) has much to do with the riders leg and stirrup length. A long legged rider on a smaller horse really needs a gooseneck type spur or he has to get out of position to use the spur. A short guy like me that generally rides bigger horses and likes a shorter stirrup to boot needs a dropped shank or the spur is continually in the horses side.
