310 -
Everything posted by PaulKrzysz
My Father was born in Poland. He said they took their axe to the blacksmith every two years for it to be resharpened. After sharpening with stones, and through normal use the axe edge got too steep to be effective in it's duty. This is how a blacksmith sharpens an axe, it is better then grinding because very little material is wasted to grinding. It's just sharpening, but done hot.
striking anvil almost done
PaulKrzysz replied to Damion78's topic in Anvils, Swage Blocks, and Mandrels
Shouldn't be too hard to weld some pieces of heavy angle to the base and anvil and bolt it through. -
If you want to move the 'anvil' from the base you can just bolt it down and forget the chaulking nightmare. -
Don't forget to brace the bottom legs -
Making Little Giant Hammer Dies
PaulKrzysz replied to PaulKrzysz's topic in Power Hammers, Treadle Hammers, Olivers
Thanks guys. I contacted Roger Rice of LittleGiantHammer, he told me the die should have the taper, but to measure to make sure because someone could have changed it. Measuring the bottom die (i could not get the top one out) I can confirm the die is tapered. -
PaulKrzysz posted a topic in Power Hammers, Treadle Hammers, Olivers
I would like to make dies for a 100lb Little Giant Power Hammer but am having trouble finding information on the taper. Where exactly is the 1/8''/foot taper? Is it in the die (Male dovetail), is it in the sowblock (female)? Is it the same for the top and bottom dies? Thanks -
Refacing a Anvil with Leaf Spring
PaulKrzysz replied to PaulKrzysz's topic in Anvils, Swage Blocks, and Mandrels
Last Video Guys. Cleaning it up, painting, mounting. -
In the video you can see we did not get a constant pour, it was a little interrupted. Near the end, to prevent the temper from running up the face i wanted to lift the anvil face-side-down in the wheelbarrow full of water (It was raised off the plastic with steel spacers). It took longer then i wanted for that to happen. Despite all of that it all turned out well, as you can see with the rebound at the end. -The horn though is softer then the main body because it was hard to get a even heat form the body to horn in my forge. -
The only other program I used was SketchUp so i do not have much of a baseline to compare to. I found Solid Edge very frustrating, but as you can see i eventually was proficient enough to draw the anvil. (Not very proficient) -
Yes I am quite happy I got this anvil finished. I am very lucky I got to use the shop at school and all of the equipment there. I am already planning the Power Hammer! Here is the video of the heat treating. I will put out one more of the cleaning / painting / mounting. Solid Edge Full Assembly Drawing -
Welded Power Hammer Dovetails
How exactly do you remove the keys in a double key system? Do the keys need to be long enough to stick out both ends? -
I got a wire wheel last week and had time to pretty it up today. I took two photos, one after cleaning, another after painting. I still need to give it a few more coats. -
Thank you everyone who contributed. I will abandon the idea of using the Hex stock. I am in College for welding and they have a plasma cutter there which runs on tracks, it can be set at a angle to cut bevels. I might use that as a option to make the dovetails. But from what everyone is saying, bolt on dies might also be a good option. I will consider both and keep you guys updated on the build. Thanks once again. -
Patrick are you saying that if both the female and male dovetails where parallel, I could just lock them in using two wedges tapered wedges which lock against one another? Seems like a clever option -
Cutting it at the right angle might prove to be a challenge. I will be making the hammer at someone else's shop so I am not sure if i could cut it like that because it would have to be resting on the table on one of the 120 degree angles. If I can do as you suggested I will, no point in wasting I don't know Thomas, how do you adjust a one piece cast iron anvil/sow block on a early style little giant? Please correct me if I am mistaken. I want to go with the dovetails because it is my understanding that it is easier to tap out/drive in 2 wedges, then it is to loosen/tighten 8 bolts (Or 4 if that is what you want to go with). I hope the extra work in making the dies holders this way pays off. -
I will begin making my Power Hammer soon. I am designing everything right now. I am trying to avail using bolt on dies. This is what I came up with. Basically, a piece of (1.5''?) Hex Bar cut into quarters, and welded into a configuration which would make both male and female dovetails. The Male end will be two pieces of the hex, with a plate on top, to the plate the 4140 for the dies steel will be welded. 1) Hex Bar 2) Cut in Half 3)Cut in Quarters 4)Weld to plate 5) Gussets welded to strengthen the dovetails 6)Drawing of Female Half 7)Drawing of Male End Please let me know what you guys think, and concerns, if it will at all work, ect.
You might be too hung up on how a flatter should 'should' look like. As Thomas suggested, just find a sledge, anneal one end as the striking end, dress the other end and use it. It does not need to have a large, upset, square face. Especially when working alone, a 2.5'' square face could be too large.
a565553e0d0c66bf6d8e40c5042f6e3c
Here is a old German Hammer Catalog. You can see two rounding hammer in there.
Bow Spring Linkage Power Hammer
Thanks guys. I will buy one new trailer spring and rebend it myself, leaving them unhardened. I'm gonna pick this one up. http://www.princessauto.com/pal/en/Springs-And-Components/1300-lb-3-Leaf-Double-Eye-Trailer-Spring/2080031.p- 11 replies
- Bow Spring
- Power Hammer
I have talked to a couple of steel suppliers and they say the demand is just not there for them to stock 5160. If I really wanted some 5160 I could do a special order ($$$). This is why I might just rebend a new spring. I can pick up a new trailer spring for ~$25, but the same material would cost me over $100 from the steel supplier. ( I got charged $12 for a 12'' piece of 3/4'' O1) I plan on filling the empty spaces with sand and oil in the structural parts to hopefully reduce some of the noise. I have considered a press, I am buying a No.5 Fly press. But I also need a tapering machine, hence the mechanical hammer.- 11 replies
- Bow Spring
- Power Hammer
Thanks for the input guys. I am only planning on doing a small hammer, something in the 25lb range, no more then 30lbs. It needs to be a quite little bugger so the neighbors don't complain. (Suburb) I cannot order new 5160 because I live in Canada. If I was to do it with bought flatbar with would be 4140. I could also buy a spring and re-bend it to my purpose. I might go with the bowspring design, or maybe a dupont linkage (Like the tire hammers). If I ended up doing this bow spring linkage out of mild steel do you guys think it would hold? Of course it would have to be beefier then if done with alloy steel, but the spring does not bend too much and the amount it does bend should not be too much for mild to return to its position. I also have a question concerning what is considered the ram weight on such a hammer, does the flywheel count? or is it just whatever is attached to the flywheel?- 11 replies
- Bow Spring
- Power Hammer
Hello everyone, I will be soon making my own power hammer. I would like to make a bow spring linkage as seen in the pictures below. From what I have seen and read the springs need to be bent far more than what is commonly available in the form of trailer springs. My Question: How would you bend a trailer spring into a near 'U' shape? Can it be done safely? Please let me know what you guys think. My idea was, worst come to worst, I will just bend them in the forge while hot, and leave them unhardened.- 11 replies
- Bow Spring
- Power Hammer
Thank you HWooldridge. You where the one who gave me the idea for this method, and you helped me a lot along the way answering my questions and so forth. This anvil have been over 5 months in the making (Late February) I now have a usable tool, I only now need to pretty it up.
