Everything posted by saintjohnbarleycorn
abrasive cut off saw
mike what kind of widths and thickness's are you cutting? thanks.
ok this one is about 10" now and of course gets smaller, I will look at the shiv ratio and see what needs to be done, thanks. kevin
what rpm should I look for? I can change the pulley size to slow it down. thanks.
I converted an old table saw into a abrasive cut off, Well just added a metal cutting blade to it. I tried some different materials on it and was not that impressed with the cutting speed. I wonder if different blades are better or is it just the nature of the beast. thanks.
vise jaws
I picked up a vise but he jaws were missing. what is the best way to make new ones, I think I can salvage the threads in the raised slot on the faces. Can I take a piece of steel and heat it and clamp it in to make the slot, or is it too much movement for the steel? Or do I machine the slot and drill it. By machine I mean cut with an abrasive disc or hack saw. Thanks for any suggestions.
Rust and moisture in the shop?
I keep an old oil rag shirt on the anvil. The electronic equipment is a bit tougher though. the big fan might use a lot of electricity. I wonder if you could just build a box that fits over each piece of equipment and put a light bulb in there with them, a 25 watt should do it? Its the change in temp that is the killer. warm air and cold steel it condenses. The wood stove would be the best bet, I would guess you have a lot of wood to work with there! good luck.
some pics of repiared forge and shop
thanks jayco, I am going to make some more additons to the opposite side I work on to get some more room. Someone suggested hang on shelves, but my forge is cracked in several places and I think that would add too much stress. I am thinking I will support it with the sheet metal side panels. thanks ice, i get the idea. At this point I have no idea where all this will lead me. But that is how I do everything! thanks for the replies. kevin
Getting Started with Blacksmithing
the fan wattage in not as important as the amount of air it blows, some people use shop vacs, something at least as powerful as a hair dryer I would think. You could also make bellows if you could not find anything else. good luck.
hammer steel
I have some old sledge hammer heads that i picked up, would they also be good, or are they softer? thanks.
looks like I didn't do the attachments right. Well you get the picture (s). How do you get them horizontal? Still have a lot of organization and cleaning up to do, but at least I can work without having to dance around junk all over the floor!
This is the old floor, removal, the patched up forge, and the finished floor. I took out an 8 x 8 section of floor and put in one ton of pea gravel. If you have any suggestions for improvement let me know thanks. kevin
Bench Grinder
there are also a lot of different wheels that you can get, ones for carbide, softer ones for carving tools. The wire brush will shoot out wire "spears" all the time so the full face mask is a must for that. The replies that mention safety should not be ignored.
Bench Grinder
the only thing I can think of is making some jigs to help sharpening. Something to use as a guide. Some I have seen slide back and forth, like for chisels to get a really even grind across.
Solar Powered forge?
there are a number of solar powered electric generators around the world. I think the largest is now in Australia, or maybe they are going to build it. The first big one that I know of is in France. they focus a lot of hyperbolic mirrors on a tower in the center, make steam and then electric.
Homemade Furnace Liner(also can be used in a fire pot)
thanks for keeping up with all my questions. I do appreciate it. kevin
patching tuyere, furnace cement/fireclay?
I"ll go get my shovel! thanks.
I reattached my tuyere today, and need to fill in cracks. there is also two slots that look like they were for a different clinker breaker. The forge I have probably had a different tuyere than this one. I have acess to fire clay, furnace cement and some stuff at home depot that is for patching fire brick that comes in a caulking tube. Which is the proper one to use, or can any of them work? thanks. again
where do you get the borax powder?
Alloy for Hammer Heads
has anyone tried hydraulic rams? they must be tough I would guess, but maybe not the right kind of steel.
grader blades
thanks I am going to give that a read.
grader blades
thanks, from the pics I saw it looked like they welded the lower one to a hardy, and then made a bolt arragment to form a shear, with a handle. The book said he could cut 1/2" hot with just the lever action, and would use a hammer if he needed more.
grader blades
I have a couple of grader blades, and I have seen pictures of them being used as cutoff tools, or shears. Does anyone have any hints or ideas to bring this about? Thanks for any help on this. kevin
Chainsaw Damascus Question
thanks for the links
Did you see this done somewhere? I would also think the different materials in the chain might be a problem, but then again it might help for all I know. let me know where you got the idea if you don't mind. thanks.
japanese forging area
Japanese Woodworking Tools, Cutlery and Garden Tools - The Japan Woodworker Catalog here is the best I could come up with till I find the post I was looking for.
