Everything posted by EdCaffreyMS
mild steel
What is generally referred to as "mild steel" now a days, is a product called A-36 hot roll. Several years ago I picked up a batch of "mild steel" from an outfit where I had always purchased it, got it home and started to work. I quickly noticed that the steel was not consistent feeling under the hammer, and that when cooled in the slack tub exhibited hard and soft spots throughout. I went back to the store and asked for a spec sheet on the steel. I was told that they did not have one, which I found odd. I started calling around, and after talking with engineers at a couple of different steel plants, I learned that A-36 was the replacement for "mild steel" to be totally honest, its nothing more than "junk" steel. Heres how its made.... After all of the specific steels are produced, anything that is left over is all dumped into one crucible, and then melted, rolled. The only specification on A-36 is that it have a tensile strength of 36,000 psi. It can contain any number of things from titanium to aluminum. Its intended for structural use, where the only concern is the tensile strength. What we would call "mild steel" is rare these days, and more often than not requires a special order on the buyers part. This stuff is inconsistent, unpredictable, and is definitely not something to use for a knife blade.
A few folder images
The first one "Golden Currents", sold for $1,750, and the third one is available for $2,150. My standard pattern folders start at $455, and the all damascus folders start around $1,000
Stainless
If its 300 series stainless, then the steel is not going to harden. If its for decorative purposes fine, but it will never be useful as a using blade. Getting the scale off is going to be a matter of elbow grease. I do not know of any solution that will take the scale off 300 series stainless. Your best bet is a wire wheel, and a lot of elbow grease.
cable finish
Once its baked on per the instructions, about the only way to get it off is to sand it off. Before I ever offered a blade using it for sale, I carried one for testing for an entire Montana hunting season. Even after going through a 1/2 dozen big game animals and everything else that hunting season brings, the baking lacquer was as good as when I applied it. Of course there were a few stains on the blade from me not taking as much care of it as I should have. :)
cable finish
The reason your getting that mottled look is due to the differences in the way the hard edge and the softer spine etch out. Since cable is all one material, there is no depth difference as there are when two dissimilar materials are used. The edge quenching is whats causing most of your problems. I stopped edge quenching damascus blades some time ago because of the differences it caused in the etch. What really got me was when a customer was going to purchase a fairly high dollar bowie, and decided not to because he didn't like the difference in the etch. (that was the last time I edge quenched a damascus blade) The pattern that is visible in cable is a result of the de-carb lines that come about when the individual wires are forge welded. OK, now to the bluing issue... I would recommend that you use something stiff/hard when sanding the bluing to achieve highlights. The way the highlights come about is from the bluing remaining in the low areas of the etch, and being sanded off the high areas. If you use something soft as a backing for your sandpaper, it has a tendency to "reach" down into the low areas and remove some or all the bluing from those areas as well as the high areas. If you want a very dramatic highlighting, try using some gloss black baking lacquer from Brownell's. You spray it on and let it dry, bake the blade at 325F for about 30 mins, allow it to cool, the using 600-800 grit on a hard backing, lightly sand the baking lacquer off all the high areas of the topography. It will give you a contrast that you can see from across the room.
The Mosaic billets I promised to show
The next time I produce some of the W pattern, I'll have to remember to take the camera with me to the shop.....without pictures to follow, it would likely be impossible to follow how to make it from scratch. All of the patterns pictured involve a number of "re-stacks"/re-welds to accomplish. The waste factor is very high on this type of Mosaic too....generally about 50%-60% of each billet ends up as waste. In order to save some of that waste, I often will keep the cut-outs from the accordion folding and "can weld" them with 1084 powder to help recoup some of the lost material.
Not sure if I'm doing this correctly, but if not, hopefully Glenn or one of the moderators with jump in here and correct it. Here are three of the four billets of Mosaic Damascus that I finished up this past week, and promised to post here. The pattern on the fourth billet was so fine and tight that I just couldn't seem to get a good image of it. That one was built specifically for folders, so hopefully when the folder is completed I'll get it posted up for those who are interested. Billet #1: "Celtic Knot" pattern: Billet #2: A billet of Modified "W" pattern... Billet #3, A billet of Multiple Radial Pattern...
Make a knife
My thoughts fall along one of two lines. First, with the proliferation of knife "kits" available today, that might be a good avenue. It will provide all of the necessary parts, and some even come with instructions. That way you will be able to see all of the required components, and can practice assembling them. They will require you to attach the handles and finish them down. If your not used to working with your hands, its a very good exercise for a beginner. The second thought is to do like most Bladesmiths/Knifemakers have done....gather what tools you think you need, then jump right in and start from scratch! As you stumble along, you'll run into things that might require you to seek advice or assistance, both of which will only gain you knowledge and experience. As you progress your going to realize you need/want this or that tool, and then one thing will lead to another. Its a path of discovery, and a whole lot of fun.
2" x 72" Sanding Belts
If your happy with the belts from the source you mentioned (I tried their belts) you'd be giddy about the belts you'd get from Tru-Grit or Pop's. When I ordered from Barbkat, I got a full selection so that I would be comparing apples to apples, that was the last time I ordered from them. The belts were not near the quality that I was used to. As with other "bargin" belts, it took 3-4 of them to do the job that one Norton/Klingspoor/3M belt would do. In this case your work will reflect the quality of materials you put into it. With the top quality belts your grinds will be smoother, more even, and just overall nicer, while using fewer belts to accomplish your task.
hmn.. Competition?
Something to keep in mind when asking for critiques on the internet...... Photos are only 2 dimensional. About the only things that can be accurately judged from a photo are the overall design, and the "flow". Fit and finish are very difficult to inspect from a photo, and are much more accurate when accomplished in person. Another aspect that is critically important is the "feel" and balance, both of which are impossible to judge unless you are holding the piece in your hand. If you really want to understand how your work is progressing, it is imperative that you attend some major knife shows and closely examine the knives present. Of course there will be all levels of work present, but the major shows will be those where the best makers display their wares, and those are the ones you should be looking at. Another venue to consider are the various Bladesmithing Hammer-ins that occur around the country. A weekend spent at a Hammer-in, surrounded by other Bladesmiths, will shave years off your learning curve. Finally, if your really serious about your knives, consider taking formal instruction from an established Maker. Generally it will cost you to do this, but the knowledge you receive will be priceless. Two individuals I can give as examples are Jon Christensen, and Dana Hackney. Jon came to me several years ago for a Basic Bladesmithing class. Since that time we have become the best of friends, and Jon has since achieved both his ABS Journeyman and Mastersmith ratings, winning both the Hasting Award (award for best knife submitted by a JS applicant) and the BR Hughes Award (award for best knife submitted by an MS applicant). Dana came to me for a basic Bladesmithing class, and then later for a Handles/guards class. Recently he won the award for Best New Maker at Blade Show West in Sept 07. It wasn't just my instruction that got these two were they are. I only showed them the tools. It took a great deal of drive, determination, and work on their parts. The point is that they did everything they could to improve, and have achieved a great deal in a short time. Things like this are what we refer to as "paying your dues". Looking back over my career as a Bladesmith, I would estimate that I have spend $15,000+ attending Hammer Ins, and both formal and informal training.....every penny was money well spent. Exposing yourself to other Makers not only spawns new ideas, but more importantly, boosts your drive and determination.
There was a time when Grizzly advertised their belts (in the catalog and online) as being 2"X76", they have since changed that to read 2" X 72", but it makes me wonder if their still not sending belts out that are longer than 72". I had some folks in the not too distant past contact complaining that the belts they got from Grizzly were too long for their machines. My response is to tell them to purchase their belts either from Tru-Grit in California, or from Pop's Knife Supply in Georgia. The belts from Grizzly are of questionable quality at best, but the two suppliers I mentioned sell only premium quality abrasives. There was a time many moons ago when I tried to "save" money by purchasing inexpensive (read cheap) belts, but quickly realized that I was wasting money because it takes 3-4 of the cheap belts to do what one premium quality belt will do.
hmn.. Competition?
When Don used the word "critique", I had to smile. At shows, I'm often asked by budding Bladesmiths to "evaluate" their knives. My response is usually.."Do you want me to LOOK at your knives, or do you want me to CRITIQUE them?" When "looking" at someones' knives, I try to be as kind as possible, while still pointing out areas that might need improvement. If I'm asked to "critique", then I evaluate the knives as if I were judging them for the Journeyman or Mastersmith test(s), as the situation dictates. I always make sure I tell the individual this, so they don't think I'm railing on them. Most of the ABS Mastersmiths will make this distinction when evaluating knives. Some folks simply cannot emotionally handle having their work "critiqued". It is not that any of us wants to hurt someone's feelings, much the contrary. Let's say that someone is planning on testing for their JS or MS rating....If I did not give a 100% honest evaluation of their knives, then I would be doing them a disservice. If I were to stroke their ego and tell them everything was great, when it might not be, then they would take off for Atlanta (the Blade Show where all JS and MS testing takes place) with their knives thinking everything is good to go. Should they fail, then because of what I did, they have just wasted a wad of money and time, only to be told "See you next year." And will probably come looking for me with a ball bat!! One of the reasons the ABS highly encourages JS and MS applicants to have their knives evaluated by as many Mastersmiths as possible, PRIOR to submitting the knives for judging, is to hopefully avoid a wasted trip for someone. People will be people, and personalities do differ. Someone who really knows better MIGHT just tell you that your knives are great, simply to avoid hurting your feelings, hence the reason to have your work reviewed by as many Mastersmiths as possible. Neither the JS or MS tests are easy. Each requires a lot of work and effort on the part of the applicant. Getting your knives ready and having them evaluated PRIOR to going to Atlanta is just good sense. Many times when I have been a Judge, I have asked individuals who have failed.. "How many Mastersmiths reviewed your work?" Almost without fail, everyone of them gave me a dumbfounded look and said.. "None." Just trying to make the point that there is more to it than just making 5 knives and going to Atlanta...at least if you want to be successful.
How did you get started kn knife making?
I actually started out as a teenager. I grew up on a large farm in southern Indiana. The community was very small, and about all a kid did was work on the farm, and hunt/fish/trap. There were only three other boys my age anywhere around, and of course on of them became my best pal. At the age of 12 he and I worked all summer, putting up hay in order to make money for purchase new knives for the coming trapping season. Late in the summer we talked his Dad into taking us to the nearest sporting goods store (about a 45 min drive) and each of us purchased what was then suppose to be top of the line knives. The first thing we caught that trapping season was a 52 lb beaver. He sharpened his knife 4 times, and I sharpened mine 5 times to get through that one pelting job! The search was on for a better knife. I started searching around the farm shop for things that I thought might make good knives. I tried to make blades from everything I could think of.... old mower blades, old hacksaw blades, old parts from machinery, I even "borrowed" some of my Grandmother's kitchen knives! (which sometimes got me in deep dutch!) I entered the Air Force at 19, and on at my second duty station met a second generation blacksmith out of Colorado who made muzzleloaders from scratch, including forge welding the barrels. One day at his outdoor smithy, I noticed a chunk of steel lying beside the forge that look like a knife blade. I asked about it and he said "Oh, thats a patch knife that will go with the muzzleloader we're making..." The light came on!! Within a month I had built myself a forge from the brake drum of an old ford pickup, found an old chunk of RR track for an anvi,l and was going to town! My first shop took shape the following summer in the form of an 8' X 12' shed that my landlord allowed me to build on the property I was renting. I discovered the American Bladesmith Society in 1984, and decided that someday I wanted to earn my Mastersmith rating. I joined the ABS and have been a member ever since. As time went by, I started to sell a few knives, and turned the money around for more and better tools. Slowly my knives became more popular, and as I became better at my craft, the quality of my work increased. Today I generally run a backlog of 6-9 months. Upon moving to Montana in March of 1992, I really became serious about my Bladesmithing. Once the moving boxes where all in the new house, I told my wife, "I've got to get a shop built." I put up a 18'X20' pole barn type building and after the first Montana winter in it, realized that eventually I would have to do something better. At -20F, it takes a LONG time to heat up all the tools just to get ready to forge! In 1994 I earned my ABS Journeyman Smith rating, and in 2000, earned my ABS Mastersmith rating. That same year I built a new 20' X 50' shop, complete with in floor hot water heat. And the journey continues. There are MANY people that have helped me along the way. The thing that has kept me going all these years is a strong love of the craft, and the wonderful people who pursue it. Most everyone I have ever met in the Bladesmithing/Knifemaking community would literally give you the shirt off their back. In 2003, I retired from the Air Force, and took up Bladesmithing full time. At first it was difficult making the transition from wearing a uniform and having 40 people working for me, to just me and my two dogs in the shop. But once the adjustment period was over, I can't imagine ever doing anything else! My favorite aspect of what I do is teaching. While I love to produce knives, I get a deep personal satisfaction from teaching others and watching them grow in the craft. I have been blessed to teach all over the world. Germany, Belgium, Canada, and at numerous locations within the US. Currently a good portion of my business is teaching others, one-on-one, in my shop. I attend about 3-4 major knife shows per year, and spend the rest of my time filling orders and teaching. I have also served as a judge for the ABS at both the Journeyman and Mastersmith levels. OK, now that I've covered my history, there is one more thing that I think needs to be said. We all had to start somewhere, and we all have/had very little actual knowledge when we began. No matter how far you go, or how successful you are, I believe that you should NEVER forget where you came from. We are all learning as we go. Everyday in the shop is a new adventure, acquiring new skills and knowledge, constantly chasing that dream of the "perfect blade". Its not about the finish.....its about the journey! Today there are more Bladesmiths in the world than at any other time in history. We have venues such as this one to thank for that. I refer to the time frame when I started out as "The Dark Years", because at that time there was no internet, and knowledge of the craft was closely guarded. Today a vast array of knowledge on Blademsithing is as close as the nearest internet connection. Thats not to say its easy, you still need the drive and determination to make it happen, but the information is more readily available than ever before.
Heavy Usage Hunting knife
If its making blades that interests you, then understanding steels and heat treating will take you further than anything. Knowing the exact steel your using, and understanding it will keep you from having to "re-invent the wheel" every time you forge a blade. It also helpful to understand the characteristics of given steels so that you can make intelligent choices about what steel to use for a given blade type/style. Some types of steels lend themselves to certain applications better than others. For example, given the choice between 5160 or 1095 for a heavy duty chopper, I would go with the 5160 based on the facts that it would create a tougher blade due to its elemental makeup. How do I know this? By knowing what elements and alloys each of the steels contain, and understanding what they impart to the finished blade is priceless to creating a great knife........the steel is the heart of a knife, but the heat treating is the soul.
Thanks for posting that info Karl! You did a much better job than I would have! I was going to put up a link, but you've got it all laid out there for everyone. Good on ya! If folks take the time to read all of the information, they will hopefully understand the level of knowledge and craftsmanship required to create a blade that will pass the performance tests, and understand that the quality level must be very high to make it through the judging phase. I would add that the test blade is really more about the Bladesmith than anything. Each of the performance tests in themselves is not that difficult, however when you combine the tests, it becomes a measure of the individual Bladesmith's knowledge of forging, heat treating, and proper geometry. The second phase of the test in Atlanta is where the fit and finish is crucial. Over the years I have heard some comment that the standards are being raised by the ABS as the years go by. Thats just not so. I've judged at both the Journeyman and the Master Smith levels, and the same rules have always applied. Whats occurring is that Bladesmiths keep getting better and better. If anyone is to blame its us. Every year somebody pushes the envelope, and raises the level of quality and craftsmanship, in essence, raising the bar for us all. I personally think its a good thing, because it means you either strive for higher levels, or you get left behind.
If your going to use 5160, and want to make it very tough, I would suggest differentially heat treating it. Another term would be selective hardening. There are a couple of different ways to accomplish this. The one I prefer is to only harden that portion of the blade that you wish to be hard. In other words, once the blade is ready for hardening, you have the option of hardening as much or as little of the blade as you desire. The general rule is to harden the blade 1/3 to 1/2 of the blade's width from edge to spine. A lesser amount of hardened material will allow the knife to bend easier, while a greater amount will make it more resistant to bending..... WITHIN A LIMIT. I have hardened some blades to within 1/4" of the spine and they still bent to 90 degrees without cracking. The other method, which I'm not too keen on, is to fully harden the blade, then do a "soft back draw". This is where the edge of the blade is placed in coolant, and a heat source such as an oxy/act torch is played along the spine until the tempering colors run into the dark blues. The reason I am not keen on this method is that very few have the patience to do it correctly. Two things that cannot be separated with steel is time and temp. In order for a specific transformation to occur within the steel, it requires a specific temp, for a specific amount of time. I have had several folks who where testing for their ABS Journeyman rating do this, and their blades failed during the bending test. After examining a few of these, and talking to the makers, it became clear that they were achieving a tempered "skin" or about .010 thickness, while the interior of the spine remained hardened (harder) . Those that have passed with this methodology, have taken as long as an hour to soft back draw their test blade(s). So in reality, either method will work, but I feel there is much more room for error with the "soft back draw" method. Why make it any harder on yourself than it has to be? Anyway, back to specifics. 5160, edge hardened at 1550F, then tempered at 350F (really your just stress relieving it) should produce an edge hardness of approx. Rc 57-59, with the unhardened area being an Rc 38-40. If you bump up the tempering temp to 375F the edge hardness numbers will drop by about 2-4 points. How supple or stiff the blade will be, depends on how much of the blades width (edge to sping) that you harden.
Kmg Sweetness
In my opinion you will not find a better grinder for the money anywhere! I've owned a KMG for a few years now, and it is without a doubt the easiest, most reliable grinder I have ever owned or worked on. Here's a link to a write up I did on my machine... KMG-article Once you get it set up and practice with it a bit, your gona love it!
Selective tempering, achieving a hamon
It could be several things. From what you mentioned, my first thought is that the tempering to blue is destroying the temper line. The line itself is a delineation in the grain structure. When you temper the whole blade to blue, your likely taking away that abrupt change in the grain which shows up as the temper line. The water might be an issue too. My opinion is that any carbon or tool steel should be quenched in oil. In this case a very light oil like mineral oil or peanut oil is called for. With 1050 you would only achieve an Rc hardness of around 55-57 as quenched, and in theory you should not have to temper, maybe just a stress relieve at 350F. If you try it, and an edge does crack, that is usually telling you that you need to sand to a finer grit prior to quenching. I usually got to at least 120 grit to prevent stress risers from forming along the scratch/grinding marks. The whole idea behind "clay hardening" is that the area covered with clay never gets hardened, while the exposed edge does, and the temper line that shows in the end is nothing more than the transition zone where the blade goes from hard to soft. You can can achieve the same thing by just edge quenching the blade, rather than quenching the whole thing. I do it on most using knives I make. Try just stress relieving the blade after quenching at 350F for two hours and see if that makes any difference. When I clay quench, I can normally see the temper line as soon as I knock off the clay.
graphite and wax
I've used that mixture before on ornamental ironwork, but I don't think it is something that would work well on a nicely finished knife blade. If your talking about knives, I would recommend a good quality automotive type paste wax with caranuba in it.
Bladesmithing School
Harvey and Dickie both are two of the top ABS Mastersmiths. Harvey is considered by many to be one of the top 10 Bladesmiths in the world. I know both of these guys, and you won't go wrong. Make sure to spend time after class talking and hanging out with both of them....you will get many jewels of knifemaking wisdom just chatting with them. Both are down to earth type people and very easy to get along with. The next time you take a look at the ABS website, take some time and read over the JS and MS test requirements.... Both of these teachers are Mastersmiths, which means they've passed both the JS and MS requirements. You don't get there without having something on the ball!
Introduction
Hi Ted! In my experience there will always be disagreements on methodology. I've come to realize over all these years that much depends on the individual, and how thinga work in their individual shops. There are of course some things that are pretty much concrete, but I often will preface a statement with "This is how it works for me." Early in my career I ran into some instances where I had made a statement about how something works...and a day or two later it had become "Ed Caffrey says you HAVE to do it this way", when I had said no such thing. Now I try to let folks know that I certainly don't know it all. In fact the more I learn, the more I understand I really don't know that much! I've had a bit of time to wonder around the site, and am very impressed with what I've found. I hope to be able to contribute to the "Blue Print" section, and look forward to the chat room.
- Blue Saturday
A few folder images
I was going to post these in the "Gallery", but keep getting error messages, so I thought I would try here..... These are a few of the folders that I've produced... This is one of my "Gents" folders. All Mosaic Damascus, titanium liners and thumb studs, heat colored, with rubies inset into the back spacer. "Golden Currents" Photo 1 Next is my "Progression II" folder. This folder has a blade of 52100, titanium liners, and G-10 handles. It was produced for a local rancher friend. The clip is engraved with the individual's brand. Photo 2 Finally, this next folder is all Mosaic Damascus, with engraving.... Photo 3
Degreasing blades before etching: What to use ?
I agree with the acetone. I usually follow that up with a quick shot/cleaning with windex, then etch.
Welcome to folders
Hi Bill! That is a NICE piece you got there! Your rockin-n-rollin on those folders!
