Question ?
The flares I've seen (online) have set screws to hold them onto the burner tube.... Is this to allow an air gap between the burner tube and the flare or only as a method of attaching the flare? Does the flare fit tightly with no air gap at the connection ?
For the sake of discussion could a say 3/4" threaded flare be attached directly to a 3/4" burner tube if the flare was shaped or even turned to correct internal taper on a lathe ?
From this conversation what I'm getting is that the flare would be better if it was the entire length of the burner tube instead of just the final 2 inches of the flare tip....??? If that's the case couldn't a 8-10" tapered tube be formed for use instead of a 3/4" pipe 8-10" long with a flare attached on the end ?
I understand "making" that flared tube would be more involved than a piece of pipe with a flared tip,but I can't see it being that difficult if doing so would improve the function of the burner...
I'm only asking because I really don't know, but wondered about how the flare was mounted while examining various burner threads and photos...
I happen to know a guy that gets Titanium extrusion tubing scraps from a plant nearby that makes aircraft tubing... I use the larger tapered pieces as breaker bar extensions around the shop,but I see no reason I couldn't cut a short section of about the right diameter and length to use as the burner tube ...IF ... having a taper the length of the tube would be better than just a short flare on the tip... ???
I'm not sure what the internal taper on these pieces are,but I'm going to check. The taper seems very gradual in the small diameter pieces and I assume the end could be threaded for this use.
