Everything posted by Bentiron1946
table legs
WOW! Those are some hot looking table legs and they work very well with the machined brass of the port and glass, very nice contrast between the black of the steel and polished bright brass. You done good, very good indeed!
177
Have Sam show you the cast bronze tsuba I sent him for one of his swords. It is the crane motif too.
cast into ant colony
We're always trying to kill off ants but they are really a very beneficial little critter, just look at how the aerate the soil, much better at it than I am. I don't mind them as long as they stay out of the house and don't kill my baby tortoise or box turtles when they are hatching. And, yes, I do realize that some species are invasive, destructive and are just not right for the local environs where they have taken up residence and that they do pose risk to livestock, native species and humans.(Sorta like Africanized Bees)
New Member with questions
You can purchase bronze casting shot which is the easy way to do it, don't buy an ingot, it will be to cumbersome for small scale casting. I bought a couple of ingots when I first started out and man does it take forever to cut of a chunk small enough to fit into a small crucible, at that time I didn't know about casting shot. When you use wood for fuel what you are actually doing is turning it into charcoal as you burn it, it is therefore more efficient to do that before you start the melting process. Therefore learn to do this before you start the melt, get plans for making your own charcoal retort, it will make your melt go a lot faster and produce a much hotter heat. You need to get a heat of about 3,000 degrees around the crucible to reach a melt temperature of 1,900F and a really good pouring temperature of 2,150F and for that that you need a good supply of charcoal on hand even for a small melt. You just don't want to get your metal to the slushy stage and get no further because you are constantly feeding food to the fire and can't make it past that stage, to get there you need charcoal which will burn hotter than just plain wood. The ancients figured this out, you don't need to, you just need to follow their example.
Slate Shingle Hammers
I didn't know there was still a call for slate hammers, are they still making slate roofs? Nice looking hammers and with them being painted red they won't be easy to loose will they?
Bronze= copper+tin(traditional) bronze=copper+silicon(contemporary)may contain traces of other metals to improve characteristics Brass= copper+zinc may contain traces of other metals to improve characteristics Scrap bronze is harder to come by than scrap brass. Scrap brass is the stuff that a lot of plumbing stuff is made of like hose bibs, shut off valves, unions, stops, tail pieces and in some electrical items like light fixtures. Now it hard to find scrap bronze and that you find in some really high end electrical products where there is a high corrosion factor involved. Most all bronze used today is silicon bronze for it ease of casting. Traditional tin based bronze is almost only used in fine arts casting. Brass and bronze are very close to the same temperature for casting, so don't fret about that. Silicon bronze is the easier of the two to cast, brass the harder and more dangerous, it off gasses zinc which can be bad for you health. Only do casting in a well ventilated area, preferably outside, watch the temperatures and don't overheat it to the point where you start off gassing the zinc. Brass needs to be degassed with a degassing agent so you don't get a lot of porosity in you metal.http://www.budgetcastingsupply.com/Brass_Degas.php Casting is something one can learn with research at the library, I did, it is possible and it is a fun thing to do but be sure you do an awful lot of reading. Remember if the ancients could do it so can you and the internet wasn't even invented when I taught myself how to do it. Yeah, that was almost back in the Late Bronze Age.
Carpal tunnel issues
I have it too, done a lot of hammering, the worst of it from repousse/chasing though, lots of short whipping strokes have done me in and that has only been in the last 5 years. The other 40 years of heavy forging didn't seem to contribute much to the problem it seems. Some folk are more prone to it than others. Using the wrist braces seems to help at night as it keeps the hand and wrist from curling up in the normal relaxed sleep mode. I have also developed another problem that is bothering my hands, both of them, not just my dominate. One idiot doctor wanted to operate on both wrists but she was wrong, it's my neck that's the problem, between C-7 and T-1 there is a nerve that is being impinged when I lay down that cause the most of my night time tingling and numbness, sure is an aggravation, so I need surgery there too beside my right wrist. I've been through the physical therapy and braces for both wrist and neck so now it time for the knife, not looking forward to that at all, however there is an endoscopic method that is supposed to get you back to work faster with less complications than the old open incision. I just don't know if it is covered under my insurance. Oh well, good luck with you procedure and I'll be praying for you.
Where to buy rounding hammer
If you want a good commercial rounding hammer made by a Master Farrier contact Jim Keith, they are a top notch hammer. He lives in Tucumcari, NM, just Google him.
Possible 2nd Anvil
Congratulations on a near perfect anvil, it's OK to aim for perfection but that will often frustrate you. I'm just trying to make the next one a wee bit better than the last one, there is always room for improvement but perfection will only bring misery.
You can melt aluminum with a wood fire but not much else in the metals that require higher temperatures like brass or bronze, like Thomas says for those you will need charcoal. I have made a number of melting furnaces out of metal 5 gallon buckets, crushed fire bricks,bentonite clay(think cat litter) and portland cement. This holds a small crucible real nice and then I use a homemade propane burner and shop vac as an air supply, melts around 10# of bronze pretty quick.
Viking Seax- My First Commission!
Nice looking effort, a real sticker you made there.
Possible 2nd Anvil
That's a nice looking anvil and not very dinged up, what do you want perfection from a used tool?
oops, gotcha moment
I like, or disliked, the story about the chain, many a jeweler had a horror story about polishing a gold or silver chain for a customer and then getting flogged by it as it gets wrapped around the polishing lathe spinning at 3,450 RPM. A jeweler friend of mine had to have over 80 stitches in his hands and forearms before he could back away from the machine, those fine gold chains cut deep at 3,450 RPM. Now a jeweler will just throw the chain in a rock polishing drum with some stainless steel shot to polish it up, no chance of it getting caught in the buff.
Angler fish 3
That is one nice piece of work, so cool! You done good!!
I found the one
Nice find for $50, now go light off the forge and get the hammer and make something! Enjoy!!!
What is it? (guys who use the old stuff)
Just to let you know, antique = 100 years or older, collectors item = 50 years or older. I'm a collectors item not an antique no matter what my children think, Happy Father's Day.
oops, gotcha moment
My little almost unnoticeable scar on my left wrist is from trying to learn forge welding, I got angry. Anger has no place in the shop but I used to have a real temper and would throw hammers, tongs, well anything at hand or in my hand. I had a 1/2" piece of mild steel I was trying to forge weld and it just wasn't a happening. After about the tenth time on a 104F day I got really angry and threw it. It hit something and came back straight at me and I put my left arm up to keep from taking it in the gut. The last time I threw hot iron ever. Anger has no place in the shop. Now when something ain't going right I just leave everything and go do something not associated with anything even related with metal. I go talk to one of the dogs, it's just like talking to a Marine, they haven't a clue what you're talking about but they look like they do and that helps a lot.
Forming 3/16 Bronze
I'm with Kustomsteel on this one, bump the thickness up to a 1/4" and cast it in sections and then weld them together and chase the seams. You don't need to cast it all in one big pour and if you want you could do each leaf separately in three sections and then weld them together. I know foundries are getting an arm a leg in fees these days, a friend of mine is getting all his stuff cast in Mexico because of the high prices here in the USA.
Nanotechnology in ancient Damascus
Interesting discussion. One of the things I like about the ancient metal workers was that they turned metal working into a religion and as long as they followed the proscribed method of worship everything usually turned out OK, it's when they blasphemed that things went bad and sometimes great strides in metallurgy happened. Maybe it just wasn't the ore body collapse but other factors included that caused the "secrete" of true Damascus steel to be lost.
Saying hi and my short sword
That is a real work of art and I guess function but that's hard to prove these days of relative peace and quiet and real nasty folk carry guns, still is a wonder to look upon.
Found my prize anvil, but what brand and how old is it? Can you help?
Nice Fisher and all those tools, your sure got a good deal and then some. You must be living right for sure.
cannon2
That's a pretty good lawn ornament. I hope you don't plan on firing that any time soon. Maybe it would work as a carbide cannon.
My twin baby girls
Such wee tiny things, May God bless you all and give you and them strength, God holds you in His hands as you hold your girls in yours.
Silver Fire
I don't know where that is in New Mexico but you have my prayers for the safety of the homes and the well being of the community. Fire is bad, I hope it wasn't man caused but by nature cause, it is somehow easier to take when it's caused by a storm than by malicious intent. May God protect all who fight the wild fires that rage across our nation and encourage and bless all those displaced by them. Amen Jerry Looked up where your town is located and I have taken the road from Demming to Hatch several times and those are sure some pretty mountains north of that road. Take care and go with God.
Double edged sword blade collaboration
OH, I like the sling shoot guy, he's as nuts as can be!
