custommetalman
pickling copper
9 posts in this topic
Really depends on how good you need. When I am in a hurry I use Vinegar with good results.
Share this post
Link to post
At work we sometimes have to bright dip parts that we zone annealed, and all we use is CLR, same stuff that you use in the bathroom to remove Calcium Lime,& Rust. Takes just a few seconds clean the oxides off.
Share this post
Link to post
Share this post
Link to post
I use Sparex #2 which works quite well and is commonly available at jewelry suppliers. I have been told that Ph down, which is sold for swimming pool maintenance, is roughly the same chemical and cheaper besides. You mix them with water to make your pickle solution.
Share this post
Link to post
An old crock pot marked NOT FOR FOOD USE makes a great pickle holder as you can set it to low and hot pickle works faster!
(and I second Sparex #2/ph minus)
Share this post
Link to post
Ph down and hydrogen peroxide. When done pickling alot of copper you can use the solution to plate steel, duel purpose
Share this post
Link to post
Do you add any salt?
Share this post
Link to post
For me the easiest to get and cheapest is PH down or PH minus seen it labeled both ways.
I buy it at Walmart. It is for balancing the ph in a pool or spa. According to the label same material as sparex but a lot cheaper. Mix as much as will displve in hot water.
Also good to cleaning scale from iron but dont use the same batch to do both as Iron in the solution used for copper the copper will come out of suspension and coat the steel
Some peole are alergic to it so were gloves and dont get it on skin.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
