Syd Partridge
    22
Profile Information
  • Gender
    Male
  • Location
    Tipton UK
Recent Profile Visitors
2,102 profile views
  1. Thank you basher. I have been very liberal with oil lately, due to it thinning and running out with the hot weather we've had. Perhaps, now it's gone cooler I need to go back to just a small amount. The clutch engagement ring is sloppy. I assumed this was used solely for engagement and centrifugal force threw the clutch out but from what you say it also disengages the clutch?
  2. Thank you, it worked. Brass rod seemed to absorb the impact so I ended up using some mild steel bar and a copper hammer and it just popped apart. Really appreciate your help I'd anticipated having to strip the top down and using some serious heat with a puller. Yes, clutch was seized but free now. I did check after you commented as I hadn't considered that it may have stuck on the shaft. Thank you for the thought, I shall bear that in mind for the future.
  3. I hope I'm in the right part of the forum. I have a belt driven Samuel Platt Goliath. Had a few days off, came in this morning, pressed the starter - belt not moving but Motor running fine then I noticed the clutch was fully engaged and I cannot seem to shift it. Don't want to be too heavy handed as it's cast iron. Any ideas please. I've added a couple of images showing front and rear.
  4. Thank you all for your help. Definitely oil but not too much. Excess runs down onto the tools and throws the job out - quite painful! The problem with the single speed seems to be that the clutch also needs oil on the plates. I was told about this and couldn't believe it, but it works. Hammer now working like a dream. Thanks again.
  5. May be too late now, but I second what basher said. Also check for cracks on top flywheel/clutch.
  6. Hi Tom, Lovely work. Enjoyed your tutorials with the help of Google translator and that's a really nice patina you achieve. Is the method described anywhere on your site?
  7. I adjusted the dovetails and now have new keys. This has solved the problem of the tool moving. However, in my wisdom I thought while I was on the job it might be an idea to clean all the bushes & pins and replace the leather belt - wish I hadn't. Previously I could adjust the speed using the treadle. Now I have one speed - about 300 strokes per minute and I can't keep up with it! Now I'm going to try grease and see if this will slow it down.
  8. Nice job. (3/8 " x 1-1/2 " flat forged into a swage block for a dome) Are you forging the nail profile or swaging through the header?
  9. If you intend trying your hypothetical question: When you have poured your first cast allow it to cool slightly, then push steel rods into the aluminum with half of the rod showing proud and allow to cool (you may have to support the rods to stop them falling over). The rods should be nicked so that the aluminum has some purchase and warmed before use to ensure they are perfectly dry (remember that rust holds moisture so ideally use bright steel). Before making the second pour, warm your first casting to just below its melting point. This will ensure both the mold and casting are absolutely dry and will reduce the draw of heat from the next pour. The second pour can now be made. If the second melt of aluminum is hot enough it, will slightly melt the base, allowing the two pours to melt into each other. This will only happen at the interface. However, I don't advise using this technique for anything you are going to hammer on, as the adhesion between the faces will not be good. We used to make aluminum 'off the wall' paperweights by pouring a small amount of aluminum onto a flat plate, allowing to cool a little, then pouring a small amount on top of this and then repeating numerous times until it looked like something that could be displayed in the Tate Modern. With regard to pouring copper onto aluminum, it is unlikely that you will get any bonding between the two materials as the aluminium will draw the heat from the copper causing it to cool before any intermetalic bonding can take place. As a note; full safety protection should be used when working with molten aluminum. In fact I prefer a full face visor in preference to safety glasses. Aluminium and moisture can be an explosive mixture and is extremely painful when it burns.
  10. I use a farriers forge with no pressure gauge only an adjustable regulator with no problem. I'm not familiar with this model of forge but I add the following comments for what they're worth. With the new fire bricks you've put on the floor, have you increased the height of the floor? If so you will have reduced the size of the combustion chamber which could affect the flame and also, if the floor is higher than the original your work may be sitting in the cooler part of the flame.
  11. That's impressive. I know competent patternmakers who would struggle at a fraction of that size.
  12. Blacksmith's Prayer - Seth Lakeman I spend my day praying I'm going to get this job right!
  13. iron Quake, thank you for your suggestion. However I'm unable to find a supplier of Chevron Way Oils in the UK. I will investigate to see if there is a similar product available. Interesting that they protect cast iron and bronze surfaces from rust and corrosion. I've also found, like you, that molybdenum grease works very well on bearing surfaces. I also like a mixture of plumbago (graphite) and oil.
  14. This looks a really good job. Would love to see more pictures as the build goes on. Where did you find the cast iron tuyere from?
  15. Thank you for the welcome. I look forward to learning here and will give back what I can. Beth - Tipton is in the heart of the Black Country not far from Cradley where all the chains were made. These days we are just a part of the West Midlands.
