Scrounging for Brass
nashdude
I started my knife shop on her maiden voyage yesterday and ground out (yes, ground---no forge yet :o) a pretty decent blade. I've got a deer antler ready to go on the end of the tang, but I was wanting to finish it up with a brass guard, preferably a hunk that's somewhere in the neighborhood of 1x2x2. Thing is, I got NO CLUE where to scrounge for brass.
A buddy of mine found some cheap brass "door treatment" at a local hardware store, but no joy at mine. Suggestions? Thoughts? Outside the box?
If you decide to collect brass and remelt it be careful of the fumes, many brass alloys use lead as a component. Use proper ventilation and don't overheat or you'll burn the zinc out which is another fume hazard.
Old faucets are a decent source of castable brass.
Frosty
If you need to cast some head to your local shooting range/popular shooting area. If it's a privately owned range ask permission of the management. Look for brass-coloured cases, some stuff can be mild steel or aluminium these days. Certainly observe the warnings posted above. (I had perhaps 100,000 .22LR cases I was going to cast into something useful just to get it out of the way, but when the scrap prices skyrocketed we sold it at nearly
Not trying to show it off, (ok, may be a little ;)), but this guard was simply cut from 5/16" brass plate. I got mine from the tool and die scrap pile where I used to work. Both pieces were cut from a piece no more than 1" x 3" 5/16". You might see if there is a machine shop in your area that may have small scraps. They often keep such small scraps for quick one off runs. Its just my two cents, but I wouldn't recommend using anything thicker than your final guard or but plate thickness. It's just that much more material to remove. Hope this helps
11027.attach
