Different kinds Posted May 26 Share Posted May 26 I have been thinking about making a forge, but I wondered if I could use a pvc pipe to route air from a blower to the part where the fire is. Quote Link to comment Share on other sites More sharing options...
Different kinds Posted May 26 Author Share Posted May 26 Would it melt? Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 26 Share Posted May 26 the PVC can be used, but not recommended for it to be directly connected to the forge tuyere. Ideally using it to supply air up to about 5ft and then switch over to metal. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted May 26 Share Posted May 26 Something like a dryer vent hose is what i have seen a lot of people use. I use 3" exhaust pipe with a "T" welded in. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 26 Share Posted May 26 I wouldn't use pvc unless it is only connecting the blower to the T pipe on a bottom blast forge or further back on a pipe on a side blast forge. Which are you building? I use 2" black pipe tor the T on my bottom blast forge. In some building or plumbing supply stores you can buy pre threaded sections to connect easily for the T. Other metal pipe could be used. Quote Link to comment Share on other sites More sharing options...
Different kinds Posted May 26 Author Share Posted May 26 Ok. I might actually try to make a coffee/paint can forge with propane. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 27 Share Posted May 27 Ok, well that would be a different animal for a different topic. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 4 Share Posted June 4 I think we're assuming you're making a solid fuel forge but . . . are you? On a solid fuel forge you can get away with plastic hose so long as there is a couple feet of steel between it and the firepot. Do NOT hang the hose below the firepot or unburned flammable gasses will collect in the hose waiting till you turn the blower on. If you're lucky it'll only pop but if much collects it can split the hose, and other wise damage things. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
