grimme Posted October 22, 2008 Share Posted October 22, 2008 got some 1/2" thin wall pipe, blanked one end and drilled a 2mm hole in it, placing this on the floor i tried differant size pipes, 1" -thru to 2" about 8" long over the end of the 1/2" to make a burner then with a long, long pipe to an adjustable reg on the bottle, what effect does the length and diameter outside tube have aslo what difference does the position of the jet in the length of the tube make, and naturally aspirated or blown air??? and lastly and most important what saftey features should my forge need when im stood next to it not 40' away in experimental mode Quote Link to comment Share on other sites More sharing options...
racer3j Posted October 22, 2008 Share Posted October 22, 2008 Google Ron Reil.mt Quote Link to comment Share on other sites More sharing options...
hill.josh Posted October 23, 2008 Share Posted October 23, 2008 yea that guy has just about all the info you need.. and to answer your last question safety glasses and a cutoff valve not including the regulator (it will still let out about 1 psi when closed) which could be just a standard ball valve from ace or homedepot, ace tends to carry it alot more often though. The reason for the second valve is so you can turn off the flow immediatly if gets out of hand instead of turning it off at the tank. Plus some gloves until you know everything is safe. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 23, 2008 Share Posted October 23, 2008 Getting an aspirated burner to work is not an easy task; far better to start with a known good design. Blown burners are much easier to work with as they have a much wider range of working needing only gas control, air control and mixing set up. Quote Link to comment Share on other sites More sharing options...
grimme Posted October 23, 2008 Author Share Posted October 23, 2008 thanks, where do i look for "Google Ron Reil.mt" ? cant find anythin? Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 23, 2008 Share Posted October 23, 2008 Use this link ----> Ron Reil Quote Link to comment Share on other sites More sharing options...
