Hefty Posted December 9, 2023 Share Posted December 9, 2023 Hi All, Can anyone in the US confirm that Mr Volcano burners are still available for individual purchase? I'm looking on the US and AUS Amazon sites and I can't find the burners by themselves. They aren't even offered on the Mr Volcano website?! I'm still seeing people refer to them as a great deal at the current price (and I'd love to drop a Christmas hint to the wife) but I can't find them anywhere! Any help greatly appreciated! Jono. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 9, 2023 Share Posted December 9, 2023 I think they were on Amazon, not sure though. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 10, 2023 Share Posted December 10, 2023 I bought mine through Amazon.com; they are no longer offered there. I think they woke up about what a how undervalued they were, and withdrew them Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 10, 2023 Author Share Posted December 10, 2023 Dang, that's what I was afraid of. I would almost consider the whole kit but I've already got a forge shell to put it in! (Hopefully, a new thread soon to be posted!). Oh well, I'll just have to put my two little 3/8" burners in it, instead. Cheers, Jono. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 11, 2023 Share Posted December 11, 2023 Nah; you can't walk away with a line like that! Tell us about those burners Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 11, 2023 Author Share Posted December 11, 2023 I've posted about them previously but I can't remember where. Burners 101 or AHB's 3d printed burner thread, I think. With advice from you, Frosty and AHB; and Trevor84's 1/4" micro "pocket rocket" as a template I made my first one and then accidentally created parallelogram intake holes on it when it twisted in the lathe chuck when I threaded it. I also asked questions in the forges 101 section about casting flame retention nozzles into the forge shell for them, but there was some confusion and things were lost in translation. Anyway, I've just finished casting a monolithic interior shell out of castable refractory and I've (hopefully, provided everything's set well) cast two burner ports with nozzles in situ. ...oh okay, here's some pics of the shell casting up (Sorry, haven't got any photos of the burners on hand): The mold, made from too many pieces of PVC and clear Perspex. The top piece of Perspex and the outer PVC pipe are both split into 2 pieces. Everything cast in place. I originally wanted a flange like this on both ends to contain the ceramic wool I will put around it but I couldn't figure out how to cast it in one go. The whole thing sitting in a plastic rubbish bin on a brick over some water for a humid set/cure (lid went on after the pic). I hope de-molding it goes easier than I'm expecting it too, or I might end up snapping off the surrounds of the burner ports. Fingers crossed! Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 11, 2023 Share Posted December 11, 2023 I did something similar when I made my first and only cylindrical forge but I used "Sono tubes," the cardboard concrete forms used to make footings and pillars. The OD of the inside one is the ID of the forge chamber and the outside tube has an ID 1" larger for a cast hard refractory flame face 1/2" thick. I drilled the burner port after it set but before it was fully hard. I made the ends by rolling the refractory, cutting the openings and sticking on the ends after I inserted the insulated inner shell into the pipe shell. It didn't go as smoothly as it sounds here, now but it worked for a first propane forge. It only had 1" of Kaowool outer liner and I wrapped it around the set and cured flame face inner liner and compressed it with paper and masking tape so it'd slip into the shell. Were I to use the technique now I'd cast burner flares into the hard liner too but I probably won't make a cylindrical forge again. How did you mold the flares? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 11, 2023 Author Share Posted December 11, 2023 After all the to-ing and fro-ing, I ended up opting for stepped nozzles in the end, because I could simply wrap some greaseproof paper around the same tube stock I made the mixing tubes and the nozzle spacer rings out of. The larger tube was intended to pull inside the ID tube and the smaller tube out through the OD tube and extra forms I had protruding. Unfortunately, I relied too much on the plastic to not stick to the castable without extra lubrication/mold release agent. The photos above were taken yesterday and after 24 hours, when I went to de-mold it today, no amount of careful prying and chipping could get it loose I was really happy with how hard it was, except I couldn't successfully de-mold it without breaking it. The burner mounts broke off and the ID tube was stuck fast. Being a small forge, and with the amount of castable I have, I'm not too upset, because I've learned enough to be able to re-make the mold with every section apart from the cast nozzle sections (these came out from the inside ok) being two-piece and I will spray the heck out of everything with spray oil, or similar, to enable it to de-mold more easily. I was about to re-cast everything when I realised it was getting late so I'm going to do it tomorrow. Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted December 11, 2023 Share Posted December 11, 2023 I just looked on Amazon and it shows it is still available...and with an $18 dollar off coupon today! Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 11, 2023 Author Share Posted December 11, 2023 Lee, the forge kit or the burner? Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 11, 2023 Author Share Posted December 11, 2023 I wonder if it's a location thing? I'm searching the US site, but being in Australia it might limit what I can see. Their other parts and consumables are there and they say "ships to Australia" but no burner. Might have to find someone with a VPN and ask them to search for me. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 12, 2023 Share Posted December 12, 2023 Have you asked them directly? Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 12, 2023 Author Share Posted December 12, 2023 Good point. Probably should have been my first step. Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted December 12, 2023 Share Posted December 12, 2023 Hefty. The entire forge kit, burner and all. Hefty. The entire forge kit, burner and all. I checked again today, still 18 dollar coupon. Curious thing I noticed is that there is a review from Australia. Quote Link to comment Share on other sites More sharing options...
Hefty Posted December 14, 2023 Author Share Posted December 14, 2023 Well, second time's a... something. I think it should be viable but there are some voids in it. I haven't picked up any ceramic wool yet. Will it hurt to do a short test fire with the burners in it without the extra insulation? (Apart from it getting hotter on the outside). Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 14, 2023 Share Posted December 14, 2023 That I don't know Hefty, without insulation around it it's going to cool off REALLY fast. I don't know if it'd be fast enough to cause it to crack or worse break apart. Patience is a good thing. It won't eliminate problems but it sure can reduce them. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 14, 2023 Share Posted December 14, 2023 I agree with Frosty. If it was just a simple cylinder shape, you could get away with heating it up as is. However, you have three different hard right angles in this casting, which is not advised. Thus, you don't want to press your luck any further. Quote Link to comment Share on other sites More sharing options...
