October 12, 200817 yr looking to set up a coal forge.. and i don't want to go back to using the small 6 inch stove pipe.. too smokey for me.. are there any cheap sources for pipe.. say 10 inch or do you just combine two 6 inch stove pipes..? Greg
October 12, 200817 yr for me i would just go to homedepot and they have 10 inch but its galvy. yes snapping 2 togethere would also work!
October 12, 200817 yr I bought my Pipe at Home Depot, look near the dryer vents, and house registers. I believe mine is 12 inch....
October 13, 200817 yr Where do you live? If you are near an agricultural area, consider looking for grain auger pipe. They come in sizes ranging from five inch diameter up to over fourteen. You can put one inside ther other for insulating purposes. The pipe also varies in gauge thickness - so a cautionary note on how heavy it may get for long lengths is needed as well as a suitable means of supporting it. I currently have an eighteen foot long length of eleven inch diameter three-sixteenth wall (or so) - salvage from someone else's misfortune while the auger was in transport.
October 13, 200817 yr home depot can order it in for you from the HQ but it takes some conversation and persistance on your part to make them check the computer scence it is not a normal product in black iron
October 13, 200817 yr Look for materials. I use a 24 inch diameter chimney and it works for my forge. Jerry Carroll suggested the inside of a hot water heater, 11 ga pipe in 14, 16, 18 inch dia. The outside thin tin metal can be rolled into what ever diameter you want. Be careful of the coatings it may have. Why not start looking for round things. Industrial or ag *things*, or look for culverts, drain pipe, or if your in oil field country 10 inch or what ever size drill pipe. And who said it had to be round? Square works. So think HVAC, welding two pieces of BIG angle iron together, or welding 4 pieces of plate steel together. Nothing wrong with using 6 inch and a BIG vacumn fan to suck the smoke out of the way. Why not use 3 or 4 ea of 6 inch pipes ganged together? The whole idea is to get rid of the smoke, not now you got rid of it. You only have to think outside the box if you box yourself in to begin with. Your a blacksmith, do what blacksmiths do best, solve the problem.
October 13, 200817 yr Author thank you all...... thats good stuff now i'm back on the hunt for it... you gave me some good ideas :D Greg
