Mikey98118 Posted June 30, 2023 Share Posted June 30, 2023 BTW, it is quite common for the super-heated steam, which is generated while the refractory is heat curing, to snuff burner flames. If you drilled a weep hole in the bottom of your forge shell, it would spit and drip water until the cure is nearly done; that would give you a visual cue of just how much steam is being generated, for a while. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 1, 2023 Share Posted July 1, 2023 Don't mistake efficient for effective. No, trimming the mig tips won't change the basic build mistake. If you decide to trim them remember to clear the burr with torch tip files or the flame will be . . . Poo. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
