sfDuck Posted November 1, 2022 Share Posted November 1, 2022 Do we have plans for building a belt grinder.? Would anyone like to throw their hat in the ring. Thanks guys Link to comment Share on other sites More sharing options...
Dave Murray Posted November 2, 2022 Share Posted November 2, 2022 There's a video on you tube where a guy made a 2"×72" grinder from a treadmill motor he got free and the wheels off a skateboard..claims its as good as any grinder he's ever had. Link to comment Share on other sites More sharing options...
Arkans Posted December 14, 2022 Share Posted December 14, 2022 I am new to blacksmithing but I have been playing with an idea and design made from an old bench grinder. Still working on the design, but the short sweet version is buying the belts and wheels and using some 2 inch square tubing and plate steel, my problem I am working on is I want to be able the change the configuration for different grinding needs but still have the work deck for things like knife jigs and such. So if I ever get what's in my head on paper, I will share it. Honestly I have seen these grinders online, I thing I can make one cheaper than I can buy one. Link to comment Share on other sites More sharing options...
Jimw3326 Posted December 14, 2022 Share Posted December 14, 2022 I thought about building my own but by the time I added up everything it was a small amount to pay extra for a tried and true base that would be at my door before I could collect the parts. The expense is the motor, which I had a compressor motor already, and variable control. I opted to go the belt and pulley route to keep the cost down. One of these days I'll upgrade it. I don't necessarily like to reinvent the wheel, just modify it. It ended up costing about 750 and was running 5 days after ordering. Link to comment Share on other sites More sharing options...
Frosty Posted December 15, 2022 Share Posted December 15, 2022 Making a belt grinder isn't hard IF you know how to weld well and control the pulling so everything comes out square and true. It is NOT a beginner's project if you want one that works properly. Our club had a 2 day build clinic and purchased materials in quantity including motors, the member price ran $130. I salvaged a 220v single phase 3hp hot tub motor and have yet to put a speed control on it but it works a treat. If you're not an experienced welder fabricator I highly recommend you buy one. Frosty The Lucky. Link to comment Share on other sites More sharing options...
navasky Posted December 15, 2022 Share Posted December 15, 2022 Do a google search for "sayber osg" Link to comment Share on other sites More sharing options...
Arkans Posted December 16, 2022 Share Posted December 16, 2022 I am a decent welder but way out of practice. Frosty do you have a link to where I can find that kit? Link to comment Share on other sites More sharing options...
Frosty Posted December 16, 2022 Share Posted December 16, 2022 Sorry no, I wasn't in charge of ordering the materials. We built the rest. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Arkans Posted December 16, 2022 Share Posted December 16, 2022 Well, have not found a belt grinder, but I did find a bandsaw on a stand, auto shut off, variable speed (belt adjust) for 65 dollars. Tried to add a pic hope it attached Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 16, 2022 Share Posted December 16, 2022 Looks like ya done good on the metal cutting vertical/horizontal band saw. I suggest before using it a lot to pull the gearbox cover and re-grease it. That's all the maintenance other than new blades mine has needed in 40+years. Link to comment Share on other sites More sharing options...
Please sign in to comment
