Emmi Posted January 12, 2021 Share Posted January 12, 2021 I’m working with 1095 flat stock 3/16” x 2” x 9”. When I try to forge out the tip and tang i get what I’ve seen called “fish mouth.” I watched a few videos and saw smiths only hitting one edge of the steel to form the tip. I realize I had been hitting both edges. How does one avoid the fish mouth on the tang though? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 12, 2021 Share Posted January 12, 2021 For a tang, many don't they just cut or grind it off as being more time efficient that finicky forging. Did you try pointing the end first? Quote Link to comment Share on other sites More sharing options...
pnut Posted January 12, 2021 Share Posted January 12, 2021 Fish mouth is caused from either not getting the steel hot all the way through or not hitting it hard enough. If anyone can think of any other reasons I'd appreciate their assistance. Those are the only two that come to mind at the moment. Pnut Quote Link to comment Share on other sites More sharing options...
Emmi Posted January 13, 2021 Author Share Posted January 13, 2021 Thank you both! I will just grind it flat here because I have so much material I’m not worried about losing that tiny bit. I could also see not having the steel hot enough or not hitting it hard enough. I’m quite new so my hammer skills are still in the works. Quote Link to comment Share on other sites More sharing options...
anvil Posted January 14, 2021 Share Posted January 14, 2021 Forge the two corners back on a diagional to create a point. You are forging down which moves the corners together making a fishmouth Quote Link to comment Share on other sites More sharing options...
billyO Posted February 13, 2021 Share Posted February 13, 2021 On 1/12/2021 at 7:58 AM, Emmi said: How does one avoid the fish mouth I'd suggest trying this. A lot of folks do what's in the first picture, but that almost always causes a fish-mouth. By starting the taper as in the second picture, you are going to push metal into the 'fish mouth' and will be able to finish the point without having to cut off any material. Basically you are setting up the point before finishing it, or as some smiths would say, doing the pre-form first. Quote Link to comment Share on other sites More sharing options...
