Acid resist not working
I'm attempting to etch a pattern on the 440c. Normally with ferric chloride I use krylon spray paint and OPI nail polish as a resistant. But neither ferric chloride nor muratic acid would etch the steel.
So I tried 10:1 diluted sulfuric acid and it worked like charm. The first time I tried it got underneath the spray paint. The second time I tried using adhesive lamination film but I got the same results.
I'm cleaning the blade with alcohol and then washing it with simple green before I put anything on it and the second attempt I re-sanded the surface down to 1000 grit.
Anyone got any advice on what to use as a resistant?received_764415104053968.thumb.jpeg.3237c37aa9059ef17fb0adfb5e7d4407.jpeg
Have you tried asphaltum varnish?  (We used to remove it afterwards with WD40.)
Have you tried liquid paper/ White out or Masking fluid from the the craft store paint aisle? I would try the white out first.
Pnut
ThomasPowers. I'll be honest ive never even heard of it. Is it something you can get at a hardware store like lowes or ace?
No I havent tried that but I do have some one hand. I'll give it a shot!
It's a *very* traditional acid resist; an old US government spec from 1922 said it had to resist sulfuric acid, 33%, for 6 hours...
As I recall we bought a can from an artist supply or perhaps rio grand jeweler's supply.  It was 35+ years ago when I was working with the sword maker...
Well I just tried using the whiteout and the sulfuric acid started reacting with it immediately so thats a no-go. Guess I'll have to wait and get some asphaltum varnish in.
Here ya go, Matt.  This might help.
Commercial link removed per TOS
