tanglediver Posted September 29, 2019 Share Posted September 29, 2019 Here is the lab rat, a 110 pound cast steel, Russian made anvil I bought from Harbor Freight back in the 90's. It originally rebounded about 55%, which is very soft. I want to learn about hard surfacing and anvil repair. So, I had at this anvil, and I can see many fine cracks in the ground surface. The camera may or not show them very well. I tried to highlight some of them. So, I have options. Worst case scenario, I air arc the whole job clean off the top. I think it has already come to that! But before I proceed, I will seek out more experienced people in this regard. By all means, let me have it. Welding school was far more expensive than this anvil and some rods. Quote Link to comment Share on other sites More sharing options...
Steve Shimanek Posted September 29, 2019 Share Posted September 29, 2019 As long as the whole welded top doesn't come off, and no shrapnel occurs, I do not see the problem. Quote Link to comment Share on other sites More sharing options...
tanglediver Posted September 29, 2019 Author Share Posted September 29, 2019 Agreed. Therein lies the question, "as long as". Who's to say when bits and pieces might let go under energetic work? Well, there is no rush, as I have other anvils which will never see my welder used on them!! Quote Link to comment Share on other sites More sharing options...
BartW Posted September 30, 2019 Share Posted September 30, 2019 Well; grind it as clean as possible, all the cracks out and such; and heat the anvil up to really hot, only then can you weld it. Well it's a little more complicated than that; slow cooling and excact temps depend. I'm intrested in the results Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 30, 2019 Share Posted September 30, 2019 There is some hardfacing rod that is designed to spider web crack when lid down. Exactly what rod and process did you use? Quote Link to comment Share on other sites More sharing options...
tanglediver Posted October 1, 2019 Author Share Posted October 1, 2019 The rods were Stoody 31 (supposed to be equivalent of 2110) and 1105. With the exception of rod diameter, I used 5/32 and 1/8 respectively, I did what I could to follow the Gunther & Schuler method exactly. http://www.anvilmag.com/smith/anvilres.htm I preheated to 400 degrees, ran one layer of 31 rod, then one layer of 1105 rod. That's it, then I covered the entire thing in a wheel barrow full of vermiculite to slow the cooling down. I did this on a 100 degree plus July day, so there was no rapid cooling going on. It was still warm the next day. Once I got back to it, I ran a grind stone over it until only the deepest pits remained. That's a lot of what we call "padding" to burn into a flat surface, the goal being to keep the beads 1/2 overlayed on the previous one to cover the whole surface to a uniform depth. It may be that I ought to throw a layer of 7018 between the base metal and the hard surface rod, I am not sure. I believe I should contact Stoody and bounce it off of someone there. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 1, 2019 Share Posted October 1, 2019 Good Idea. Quote Link to comment Share on other sites More sharing options...
