May 18, 20197 yr My 9 year old daughter found this clip on the ground thinking I could make something out of it. I told her it was to small to use them I felt bad......... Help me think of some things I could use it for please!
May 19, 20197 yr On that theme..a base for a hair piece. Attach a simple barrette on one side, and a flower on the other, with paint that matches the flower. Maybe have her help you add sprinkles and gems, from the craft store.
May 19, 20197 yr It would probably be a missed opportunity to not get her involved. Maybe have her put the metal piece in the forge as part of the process, so you get a blacksmith out of her in a few years.
May 19, 20197 yr Author I like your idea cedar Crest! I do get the kids out in the smithy with me quite a bit. Maybe I'll let her be the striker to flatten it out too.
May 19, 20197 yr Drill a hole in a piece of wood to correspond to the hole in the metal. Glue the metal over the hole and call it a pencil holder.
February 1, 20206 yr That piece would require me to use my body hammers, and turn it into whatever it wants to become. I see a heart shaped pendant with a center stone there. It just wants to come out of hiding.
April 28, 20206 yr as you picture... take the sides in a bit, flare out the corners and insert a shiny rock in the middle and you have a butterfly or moth? weld it to a stick and she can put it in a little potted flower.
April 28, 20206 yr Since the original post was May 18 2019; perhaps it would be better to ask what he did do with it?
April 28, 20206 yr agreed, but if he is anything like me its likely the item is still sitting on his dresser... So what did you do Cocker
April 28, 20206 yr Hey; I've almost completed a project I started 16 + years ago and hope to have it done in another couple of weeks max!
May 8, 20206 yr You could melt a piece of old coke bottle into the hole, polish it up and make a pendant or something to hang in the window
