Anvil ID help
Congratulations on your find.
Pretty sure the first number is a 2... that would put the weight at 256 pounds (close to the sellers guess). If it was a 3 the as forged weight would be 368 pounds.
Your Mouse Hole looks to be in excellent shape, hope you have read about not doing any welding, milling or grinding on the hardened face. All it needs to shine is to have hot steel pounded on it. If you don't mind how much did it set you back? The last mouse Hole I looked at in my area would have left a huge hole in my wallet and it wasn't in as good as shape as yours.
