shrike Posted February 5, 2019 Share Posted February 5, 2019 I'm working from Clay Spencer's tire hammer plans, but am considering a larger hammer and anvil. The Anvil is easy, more is better, demensions don't change much. The feedback I've gotten from Clay is that he thinks 65lbs will work without change and that 90lbs won't. Has anyone got first hand experience increasing the hammer / Tup weight? What did you have to change to make it work well? Link to comment Share on other sites More sharing options...
setlab Posted February 6, 2019 Share Posted February 6, 2019 Wondering that myself, Raymond Head has the same view as Clay, this design is really only safe for 65lbs. Also mentioned to me the heavier ram you get the more sluggish it will make the hammer. Increase the motor size? I imagine there is a limit point for the motor size and how much of its power can be transfered through a direct drive friction wheel. So there must be a point to which a bigger motor would be useless to create a larger hammer. Personally I've thought about just increasing the thickness of the material used and laying down more welds than are required to create a larger hammer. At the end of the day though, a 50lb hammer is probably good enough for anyone that wants to build this design. There's less trial and error and head aches if you were to just follow the plans than if you were to modify it too. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 6, 2019 Share Posted February 6, 2019 I agree with setlab that a 50 pound hammer will be more than enough for most work. My 30 pound Star hammer has moved any steel I've put in it for the past 18 years. Anytime you start modifying plans things usually go south in a hurry. Link to comment Share on other sites More sharing options...
marcusb Posted February 7, 2019 Share Posted February 7, 2019 Slight increase in BPM? All I can think of is a Scottish Voice saying..."She will fly apart Captain!" Link to comment Share on other sites More sharing options...
Jarntagforge Posted February 7, 2019 Share Posted February 7, 2019 Regarding motor and power transferral, Little Giant 250 and 500 lb hammers may not be eactly the same but they're very similar. It's easy to imagine - is your hammer sluggish? Add power! But other than that I agree with the previous posters - if Clay's design says 65 lb then that's what the frame is designed for. You need to reinforce the frame in that case (all of the hammer) if you want a heavier ram. Link to comment Share on other sites More sharing options...
shrike Posted February 7, 2019 Author Share Posted February 7, 2019 Thanks for all the feedback. I'll keep the hammer weight down. I have lots of steel for the anvil, but I think that's a *good* thing. Link to comment Share on other sites More sharing options...
AR. Hillbilly Posted February 16, 2019 Share Posted February 16, 2019 I’m also in the process of building a Clay Spencer hammer. I’ve had a few conversations with the man up to this point. I believe that you can make the anvil, base and a few other parts heavier and make the 50 pound hammer much more efficient. A good anvil and base and good machining skills will make the best of this hammer. Link to comment Share on other sites More sharing options...
Zachariah Posted March 29, 2021 Share Posted March 29, 2021 I am trying to get a copy of tire hammer plans if anyone has a copy they can sell I have sent emails to Clay and I think Ray but no response Link to comment Share on other sites More sharing options...
jason0012 Posted April 10, 2021 Share Posted April 10, 2021 Find someone with a 100 pound little giant and get measurements. Scale accordingly Link to comment Share on other sites More sharing options...
Zachariah Posted April 10, 2021 Share Posted April 10, 2021 I was able to get acopy of the bueprints Link to comment Share on other sites More sharing options...
Please sign in to comment
