What are these?
Pr3ssure
Merry Christmas,
The inside Mic should read 0-.500". The collar is .500".
By using one/either of the stems and the collar/sleeve, you can adjust to within .500 of your required/wanted range of measurement. Generally the body base is 2.000", add the lengths and with/without the sleeve.
It is just a multi-piece jigsaw puzzle Micrometer. A little mathmatics in your head and presto, an Inside Micrometer.
Not used for Blacksmithing, necessarily, but still useful.
Neil
I once had some nicely worn ones I picked up when I bought a bunch of silver coins at pawnshops as I was buying them at bullion cost to make a pectoral cross for a friend out of 30 pieces of silver and wanted old worn not easily identifiable coins from a wide range of countries. (some had Queen Victoria barely visible on them...)
Unfortunately I now need another myself..."half the thickness of a worn Euro" just doesn't have the same cachet...
