Sharpening Tools
Owen Hinsman
For those odd shapes, you can pick up slip stones at a fairly decent price and those can really help with some of the final honing.  Here's one example but there are a ton of shapes available--primarily for woodworking carving tools with all those odd profiles.  You still need to get the initial bevel right with a coarser stone to begin with--from the photo, you may still have some work to do there,  but the actual piece is not in my hand so take that with a grain of salt.
Nice tool You made there.
On the pictures, which are quite good, I see that the edge is still much too thick.
Like most of these tools it should have a only single bevel on the outside.
If its single beveled and thin enough than You can sharpen (strop) it with a wet sanding paper file
maybe You take a look at this.Even if it is much bigger in the radius it shows excellent blade geometry, that will work fine and sharpen easy.
https://www.google.com/search?q=edge+geometry+on+spoon+carving+knife&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwiBsbSBgbvfAhWVfisKHSCTCJ0QsAR6BAgDEAE&biw=1093&bih=501#imgdii=VJoyGBHNdV4DEM:&imgrc=_pt7b00_ZpavXM:
Cheers
