Frosty Posted April 25, 2019 Share Posted April 25, 2019 Fisher Burner Mike, I have a couple. It's also where "flame holder" came from as far back as I looked. If the same page loads as I got, 4th. from the left, top row. The screen or perf plate is much older tech, goes farther back than gas mantel lamps. Frosty The Lucky. https://images.search.yahoo.com/search/images;_ylt=Awr9DtsBOcJcP38AlV9XNyoA;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=fisher+burner&fr=crmas Quote Link to comment Share on other sites More sharing options...
Daedelus Posted May 5, 2019 Author Share Posted May 5, 2019 Hey Guys, Had a nice day off today and made myself a cart for the forge (and other future forges). There are a few updates that needs to be taken care of, such as the gas-hose extender and the airtight-top-seal as mentioned before. However this thread is for the burner, not for the forge! I have the propane pressure set to 0,5 bar on the tank, and have only changed the air-adjuster on the burner intake. I did not let the forge heat up before, so I would have the darkest background to make these shots. So this is what the burn looks like, with the new tank and adjuster: Small air opening: Medium air opening: Big air opening: Once I reduce the air opening, I can get a nice blue dragon's breath, however it is quite large. I suspect I need to adjust the pressure a little lower. Unfortunately I don't have a proper shot of this. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 6, 2019 Share Posted May 6, 2019 Lets take a minute and discuss your regulator; the gas gauge looks like it is meant for acetylene; if it came with the regulator, that means the regulator is meant for acetylene fuel gas. If it is a fairly new regulator, that might be okay. If it is an old regulator that is very likely NOT okay at all. LPG gases tend to dissolve the gaskets that were used for decades in those regulators. At least in the USA, later model acetylene regulators started using safer gaskets. It would be wise to check with an expert to see if your regulator is safe with LPG fuels. Regulator fires really suck! The flames indicate that you need a smaller orifice in you gas jet; the burner is close, but not quite there yet. Quote Link to comment Share on other sites More sharing options...
Daedelus Posted May 6, 2019 Author Share Posted May 6, 2019 Thanks for the warning Mikey. Even though the regulator is newly bought from the propane supplier, a regulator fires sounds bad. (Edit: I have looked up the product/order again, and the product information is as follows: Adjustable pressure for all applications with high pressure. High pressure regulator, 0 to 3 bar Throughput 8kg-12kg/hour In 1/4 innerthread Out: 1/4 innerthread Approved for Hot Air Canons and gas burners to 55 kW. Reference: https://multiflame.nl/product/hogedruk-gasdrukregelaar-0-3-bar/ model: NC2005L) Previously I used a 0.6 mm mig tip which lead to a red hot mixing tube. After this I switched to the 1.0 mm mig tip I had. What size would be recommended, back to the 0.6mm or try a 0.8mm? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 6, 2019 Share Posted May 6, 2019 Sounds like a multi-fuel regulator. Try a .9mm MIG contact tip. Quote Link to comment Share on other sites More sharing options...
Daedelus Posted May 11, 2019 Author Share Posted May 11, 2019 On 5/6/2019 at 9:37 PM, Mikey98118 said: Sounds like a multi-fuel regulator. Try a .9mm MIG contact tip. Meaning the regulator should be fine right? I checked the hardware store today, they only had 0.6 and 0.8 mm, so I'm going to order a 0.9 mm mig tip online. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted May 11, 2019 Share Posted May 11, 2019 I think the regulator is okay. Nothing stops you from using a .8mm tip; if it is too small, torch tip cleaners can quickly enlarge its orifice a few thousandths of an inch. Either way you get what you need Quote Link to comment Share on other sites More sharing options...
