billyO Posted October 2, 2018 Share Posted October 2, 2018 11 hours ago, BIGGUNDOCTOR said: I was thinking that a lag screw could be used as a mandrel of sorts to keep the coils equidistant to each other. Hmmmm....that's an idea worth pursuing Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 2, 2018 Share Posted October 2, 2018 May want to trim off the part where the diameter decreases though. Quote Link to comment Share on other sites More sharing options...
beammeupscotty Posted October 4, 2018 Share Posted October 4, 2018 I have read that D2 rod is a good material for corkscrews. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 4, 2018 Share Posted October 4, 2018 of course D2 really needs high tech heat treating to get the most from it. Otherwise you are paying a substantial surcharge and then throwing away what the surcharge was for! Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted October 4, 2018 Share Posted October 4, 2018 D2 is a high chromium tool steel that can get super hard. I used it for the punch and die in the die sets I made in my shop. It is also expensive. I would use it for an application more suited to its full capabilities, and use a steel that when heat treated is more tough than brittle-- spring steels, medium carbon, etc .. With D2 you would almost have to use it annealed to keep it tough enough to hold up. Quote Link to comment Share on other sites More sharing options...
