Sabre Posted June 5, 2008 Share Posted June 5, 2008 (edited) hey my forge is a outside and does it madder if it gets rained on alot? thanks, sabre Edited June 5, 2008 by Sabre Quote Link to comment Share on other sites More sharing options...
Chris Pook Posted June 5, 2008 Share Posted June 5, 2008 You shouldn't need a fan to get the smoke to go, chimney work due to the difference in air temperatures causing a draft. If your working outside why are you needing a chimney? What are you trying to do? Quote Link to comment Share on other sites More sharing options...
nett Posted June 5, 2008 Share Posted June 5, 2008 (edited) Original post was edited and my response became moot. Edited June 5, 2008 by nett Original post was edited Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 5, 2008 Share Posted June 5, 2008 Your original question was about why side draft chimneys worked, the temperatures expected in the flu, and a comment on a fan to assist the draft. By deleting the original question, the answers are now difficult to understand. Quote Link to comment Share on other sites More sharing options...
Johannes Posted June 5, 2008 Share Posted June 5, 2008 it depends on the material you made it from, if your forge is made of sheet or cast iron, it'l just get rusty, and thus wearout quiker, if you'v used clay, firebrick, refrectionary concrete or something of the kind, you should watch out when lightning it wen the stone is wet,(steam presure of the absorbed water may cause it to crack or even explode, so be carefull to make sure its always nice and dry), same goes for freezing. regards! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 5, 2008 Share Posted June 5, 2008 Not enough data to answer the question---is your forge made from adobe? Rain would be a major problem! is your forge made from a brakedrum, rain is incidental. Please take off your Al hat and think real hard about the details so we can try to read your mind! Having a cover for it is generally a good idea, I've used an old trashcan for a brakedrum forge and a piece of plywood with a concrete block on top of it for a cast iron forge. Quote Link to comment Share on other sites More sharing options...
