Glenn Posted January 17, 2018 Share Posted January 17, 2018 Show me your hardie tools, those things that make the hardie hole useful. The issue when you get two anvils is that many times they do not have the same size hardie hole. You can make two hardie tools, or make a shim or converter. This was a piece of angle iron for the first converter, and a piece of thin wall tubing for the second one. All you have to do is to slip it into the hardie hole. And your anvil tool with the smaller hardie post will work on the big anvil with the big hardie hole. The ears were later thinned down quite a bit so the hardie tool fit more level to the anvil. Another way to do the same thing is by using a piece of tubing and flaring the top edge a bit so it does not go into the hardie hole. The photo is a bit strange as that is a 3/4 inch hardie hole on the anvil and a 1 inch piece of tubing to adapt small hardie tools to a larger hardie hole on another anvil.The photo was taken this way to show the difference in sizes. Show us your hardie tools, the fullers, hot cuts, guillotines, benders, etc. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 17, 2018 Share Posted January 17, 2018 I like large tabs on my tube converters as that way the hardy tooling rests on those and not the anvil face. It will be a couple of weeks before I'm back at my northern shop and can get a photo of the nested tube converter for my 1.5" hardy holes down to 1"... Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 17, 2018 Author Share Posted January 17, 2018 Thanks to Mike-hr. Then there are times when you just need a smaller anvil. So use the hardie tool in the hardie hole. Thanks to Irnsrgn for this idea. Make a hardie socket to adapt a larger hardie hole to use smaller hardie tools.This is a 5/8 ID square auxiliary socket for the hardy hole in my anvil. If I need a special small anvil tool I can forge from 5/8 hot rolled square and drop in the socket for use. saves making a big hardy shank for small tools. Quote Link to comment Share on other sites More sharing options...
Timber Ridge Forge Posted January 17, 2018 Share Posted January 17, 2018 These are mine Quote Link to comment Share on other sites More sharing options...
Lionel h Posted January 17, 2018 Share Posted January 17, 2018 I’ve just about stopped using my hardy tools on my anvil , I’ve made tools welded to some 1/2 in plate an use them in one of my vises . It holds better ,and I don’t worry if the hardy won’t fit or gets loose. Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 1, 2018 Author Share Posted September 1, 2018 A quick hardie cut can be made from a piece of angle iron and a hardie post. They can be welded or bolted together and the cutting edge formed with a angle grinder. Whitesmith Sometimes you need a 3rd hand. by Whitesmith Take a rod and mark it at about 2" and 8" from one end. At the 2" mark, make a 90* bend. At the 8" mark, make another 90* bend but turn it differently. (The two bends are at right angles to each other.) This is hard to explain in words but look at the photo and you will understand. Measurements may be different for your anvil tool. If this is done correctly, you can put it in the pritchel hole and have an anvil support for the stock that you work on the anvil. Quote Link to comment Share on other sites More sharing options...
