PCornett Posted September 16, 2017 Share Posted September 16, 2017 First off, this pic was grabbed off net cause I am at work and cant find a pic on any device I have with me. Now, after five years I have finally gotten the $15 auction find 616 free and spinning. Unfortunately, the top threaded bar and collar( that control the vertical motion) have rusted somewhat so I will have to get new ones machined. Problem is I cant get the collar that connects to the drill shaft to move. Is there something I am missing or am I just not using my manly muscles? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 17, 2017 Share Posted September 17, 2017 Just a tip: manly muscles use usually results in broken cast iron on things like this. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 17, 2017 Share Posted September 17, 2017 By not move, do you mean the shaft wont move? Up & down, around . . ? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
PCornett Posted April 1, 2018 Author Share Posted April 1, 2018 TP, even w/o muscles I broke it but I think that was more due to the drill sitting out in a field for years and rusting from inside out... Frosty, the collar that moves up and down the threaded rod is chipping out from rust on the inside. Looks great on outside but chips away up at top where the wheel is attached. I need to remove that collar to get a new one machined. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 2, 2018 Share Posted April 2, 2018 This is where getting more mature helps a lot. Having a full time+ job and other responsibilities, (I had to hold my youngest grandson yesterday while his mother did some stuff---till his grandmother came and stole him away...very polite little one; didn't even pull my beard---unlike his mother and his Aunt who managed to grab it and pull before they were an hour old!) means that things tend to sit from weekend to weekend and there is a lot of processes that do better with increased time. Quote Link to comment Share on other sites More sharing options...
PCornett Posted April 8, 2018 Author Share Posted April 8, 2018 TP, even w/o muscles I broke it but I think that was more due to the drill sitting out in a field for years and rusting from inside out... Frosty, the collar that moves up and down the threaded rod is chipping out from rust on the inside. Looks great on outside but chips away up at top where the wheel is attached. I need to remove that collar to get a new one machined. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 8, 2018 Share Posted April 8, 2018 At some point it's easier and cheaper to just get another one in better shape... Quote Link to comment Share on other sites More sharing options...
PCornett Posted April 20, 2018 Author Share Posted April 20, 2018 Maybe you are correct, but not as much fun. This stuff is my sudoku. Quote Link to comment Share on other sites More sharing options...
Daguy Posted October 20, 2018 Share Posted October 20, 2018 Don't know if you got it out yet, but when I was cleaning mine up, I put a tapered punch through that clip on it and hammered it through the opening. As the cross section of taper under the clip got larger, it started the clip moving out. Once broken free, I just put another piece of flat metal underneath and repeated until the clip came out. If yours is out, great. If not this post might help the next guy with the problem. Daguy Quote Link to comment Share on other sites More sharing options...
Heelerau Posted November 26, 2018 Share Posted November 26, 2018 How did you get the handwheel off the threaded piece, it seems to be an interferance fit, there is a grub screw which I have taken out. My handwheel has partially slid up the threaded collar, it was like that when I aquired it. The piece below with the u shaped pin, I just used a pair of vice grips and tapped it out. be aware there is a retaining groove in the mainshaft where this pin should go when replaced. I have tried some heat on the wheel but maybe not enough. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 26, 2018 Share Posted November 26, 2018 Do you have a pulley puller? I've used it CAREFULLY to remove things off shafts before. Quote Link to comment Share on other sites More sharing options...
Heelerau Posted November 30, 2018 Share Posted November 30, 2018 Thomas, borrowed my nieghbours pulley puller a little heat from a propane torch, and lo removed the hand wheel. Have now swapped out the threaded cylinder it was mounted on and have replaced it with one from a wrecked buffalo drill, and have remounted it with new grub screws. The shoulder underneath the old one was nearly gone, so this one has a good sized shoulder to take the upward thrust. Thanks for the suggestion. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 30, 2018 Share Posted November 30, 2018 Lots of specialized tools out there that a lot of people are not aware of that can make a difficult job easy. (I was once remodeling our 100 year old house's kitchen and astounded a friend who was also remodeling a house. You see I knew about a drywall jack---place a sheet of drywall on it. flip it to horizontal then wheel it in place and raise it up snug against the ceiling and we had TALL ceilings! I also knew that drywall was easily available in longer lengths than the standard 4'x8' so my ceiling only had beveled side joints to mud. Turned a multi-person unpleasant job to a simple 1 man job.) Quote Link to comment Share on other sites More sharing options...
Heelerau Posted November 30, 2018 Share Posted November 30, 2018 You are dead right about that piece of gear, we have a 110 year old timber house and I helped the tradesmen put up mini orb ( coated fine corrugated iron) up for a new ceiling and what a pig of a job that was by hand, and we have 13' ceilings. Quote Link to comment Share on other sites More sharing options...
