Iron Poet Posted February 16, 2017 Share Posted February 16, 2017 I made these specifically for welding small stock such as 1/8" to 1/4" and also sheet metal, the tines are rather springy so that you can clap both pieces rather well. You more or less just heat the metal up and then when you're ready you simply hammer between the tines. I am also aware that these are not very pretty. Quote Link to comment Share on other sites More sharing options...
seldom (dick renker) Posted February 16, 2017 Share Posted February 16, 2017 interesting. but i am concerned about having tongs in the fire for any length of time Quote Link to comment Share on other sites More sharing options...
Iron Poet Posted February 16, 2017 Author Share Posted February 16, 2017 You don't, these are just for picking the pieces up. IF you have difficulty you might need to reposition the pieces with a different pair of tongs for easier grabbing. It's better than trying to separately handle material by yourself, I can tell you that much. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 16, 2017 Share Posted February 16, 2017 Nifty idea. Quote Link to comment Share on other sites More sharing options...
Fixit Posted February 16, 2017 Share Posted February 16, 2017 Hello, Are the tines Springy by the design or the metal used? Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted February 16, 2017 Share Posted February 16, 2017 14 hours ago, Iron Poet said: I am also aware that these are not very pretty. Ah, but beauty is in the eye of the beholder. Beauty is also in the functionality of the holder. LOL They look pretty fine to me. Quote Link to comment Share on other sites More sharing options...
Iron Poet Posted February 16, 2017 Author Share Posted February 16, 2017 5 hours ago, Fixit said: Hello, Are the tines Springy by the design or the metal used? By design, so I can clamp both objects firmly. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 16, 2017 Share Posted February 16, 2017 How do they work? I'm thinking a similar set up with much thicker bits, say 1/4" x 1/2" or wider on edge with half rounds or V notches to hold the stock would let you place them cold and heat the tongs too without worrying about them getting soft. Small stock will heat to welding temp faster than the heavier bits. They'd also help keep the project stock hot longer so a person wouldn't have to rush to the anvil as fast. Just thinking. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
