September 14, 20169 yr I have a friend that can get all the cutting edges I want from motor grader and bulldozers. Does anyone know if they will make blade steel.
September 14, 20169 yr Yes I know if grader, dozer, etc. edges will make good knives. NO it won't, it's the wrong kind of steel on almost every level. The stuff is first abrasion resistant at a level that will just eat grinding wheels, cups, belts, etc. unless you're willing to spend the $ for blue. Then it's impact resistant to the point of stopping 72,000lbs. of 30mph Cat 14d road grader within a couple inches of snagging a manhole without bending. With some imagination you can make a workable shear with it. If you need to grind it low read heat and a stone cup are your best bet. The stuff is tempting but it's designed so "perfectly" for what it does it's not much good for anything else. I have a couple few pieces if anybody's interested. Frosty The Lucky.
September 15, 20169 yr I have six in my yard I planned on using for tooling. I knew I didn't want to make knives with them but tooling of all sorts can be done provided you have the patience and tolerance for abuse. I used a whole cut off blade on my grinder and made a 3/4 inch cut across one and haven't tried any more.
September 15, 20169 yr Only thing I have is grandpa's posthole diggers. Schedule 80 pipe handles & 3/4"square bar for a box hinge. Forged grader blades for the shovels. Those things will dig thru pure shale or limerock, no problem, but you'd better have your big-boy britches on.
