new to forgeing hammer question ?
ive make a few stock removals knifes  im trying out smiting question wen using a cross bean hammer with way do i hammer to spread out some 51 steel  it 2 in wide & 1/4 thick id like it hammer it wider & thinner do i stick horizontal ore vertical of the line on hammer THANK,S  any one  ?
if your wanting to widen the steel with your cross pein, or as you put it cross "bean", the pein should be parallel with your stock, the same thing can be accomplished by tilting your hammer to have a less aggressive fuller.
        Littleblacksmith
See: "cow pie theory"
Try taking some clay and "forging" it. It moves the same way (directionally) as steel will. Thats a good way to figure out elongation on tricky pieces and how to spread the material with a hammer to get your desired result.
I would not recommend trying to do any spreading of material with the straight pein hammer in the bottom photo.  The pein is shaped wrong for that sort of work.  That hammer os almost shaped more like a cutter than a straight pein.  Which orientation pein you use depends on what is more comfortable for the specific task you are doing.  When properly shaped, both straight and cross peins do the same job.
