Mouse hole
I have a mouse hole anvil 112lbs how do i know when it was made? The third pic there is some numbers but i cant read them the 4 pic is where the numbers are located and how would i price this?
Any help will be greatly appreciated
Price will depend a lot on what country you are in and can vary by more than a dollar a pound  just on where in the USA it's at for example---I don't know how the prices range in Australia if that's where you are at. (WORLD WIDE WEB)
Does it have a pritchel hole?  they generally became standard in the 1820's; but some older ones had them retrofitted.  Without more details I would say 19th century and probably second half as the feet are not real small and sharp.  Anvils generally don't get a plus on age until before 1800; I still use one from 1828 in my shop on a regular basis.
 Should be weight stamped in the CWT system: leftmost number x 112 plus  middle number x 28 (and can only be 0,1,2,3) plus rightmost number (and it can only be 0-27)  Is that 112 a weighed number or just what you were told?     I can't get 112 out of the numbers I can see. "guessed weights" are often wrong for anvils which is why we suggest weighing them.
Lastly there is no picture of the face of the anvil---that's like trying to sell a car without telling us if the engine runs!
Forgot to mention the ball bearing test to check if the anvil has been annealed in a structure fire---drops the price hugely!
That looks like the older brother of my 75lb anvil; If you're in the DC/MD/VA area, PM me, if you're looking to sell...
Regards,
RF
  • 2 weeks later...
Have you ever tried to harden & temper an anvil surface? I read about it I believe in Forge-Practice and Heat Treatment of Steel by John Lord Bacon. Looking for the chapter now. I was thinking about trying it with a piece of rail to practice.
Alexander Weygers gives instructions for hardening and annealing a rail anvil on pages 177-8 of The Complete Modern Blacksmith.
Thanks I'll check it out, I have that book too. Been saving ash for a while, mostly from the charcoal grill.
  • 11 months later...
You can determine the age by the order of the words I have one similar and it was made in 1820-1835 it is orderd  like this.
M&H
Armatige
mouse hole
The numbers on the bottom is British stone weight
          -Jonathan
  • 2 months later...
Anvils don't usually get much of a plus for age until they get before 1800. Lots of "old" ones out there.
