phabib Posted March 21, 2016 Share Posted March 21, 2016 I'm less than a month in my new space and already tools that I've had for 30 years are starting to develop a layer of rust. I'm right at the base of some hills and water my shop is on the flat spot where the water collects and not more than 30 feet from a year round creek. Last week I opened the door to see the dies on my new power hammer looking like they'd been hit with a spray nozzle, just from condensation. Others must live in similar climates so what do you do? I thought of getting a dehumidifier and running it constantly. I could install heat and keep it warm enough to avoid some of the condensation. Right now the space is slab with no insulation and no sheetrock on the inside. Ideas? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 22, 2016 Share Posted March 22, 2016 try running a fan all the time. It helps in some situations. Quote Link to comment Share on other sites More sharing options...
SmoothBore Posted March 25, 2016 Share Posted March 25, 2016 On 3/22/2016 at 9:02 PM, ThomasPowers said: try running a fan all the time. Ditto. . Quote Link to comment Share on other sites More sharing options...
arftist Posted April 9, 2016 Share Posted April 9, 2016 Water Displacer 40 WD 40 I live on the beach. I spray my tools with light oil. Be aware, muriatic acid will make iron rust also. Do not keep any in your shop. Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 9, 2016 Share Posted April 9, 2016 Keep some heat in the building, just enough to avoid condensation. Keep the air moving with a small fan. The idea is to keep the moisture from condensing on the metal. WD40 to bring the moisture to the surface, and oil (such as 3 in 1, or ATF, etc) on everything. If you can paint everything that you can paint for longer protection. There are still times here when the entire shop rains on the inside as the weather hits that perfect combination. Quote Link to comment Share on other sites More sharing options...
