Getting Started with Blacksmithing
Hey Guys i've recently become interested in blacksmithing
Where should I start?
What tools do I need?
How do i make a forge?
What are good books to read?
How do i know if its galvanized metal because i heard its fumes can kill :(
What are some easy projects?
Thanks!
I really want to get started soon!
Getting Started
Blueprints - I Forge Iron - Blacksmithing and Metalworking
LB0008 Reference material
LB0008.0001 Reference Material
galvanized metal is typically a light grey coating on thinner steels which are exposed to water or weather, a zinc coating that prevents rust till they are scratched or worn out, stick to rusty steel :P
it generally has a crystal pattern to it, if its a bright shiny surface its likely an alloy (stainless steel) you can always sand through a suspect coating to test if it rusts underneath, use a little salt water, or hydrogen peroxide
basic tools
a pipe a hole in the ground, charcoal, a way to blow air through the pipe into the bottom of the hole
steel. something to smack the steel against and a hammer
in the blueprint section are slightly more advanced forges ;)
4733.attach
Hey guys thanks for being really helpful!
:D
What would be a nice coal forge furnace to start with? With the air coming from the bottom?
Is a 12 watt ventilation fan enough? (sorry im not sure! haha)
And any safety tips for making my first forge?
Thanks guys!
This has been merged with a related thread.
a 12 volt DC blower like what is found in the air conditioner/heater in a car works fine, unless you try to plug it into an AC outlet cause someone put a standard plug on it;-) I had a horseshoer coal forge designed to plug into the trucks DC system, but it had a standard plug on it... Oh well I fixed it (several different times so far... ;-)
