Using 316L as a powdered metal for canned Damascus
J
its used as a filter media in high pressure nylon extrusions.  yep...not cheap.   if I had a buyer for it...haha.  the particle size is about like common ground pepper.  oh well, next time make Damascus ill give it a shot..
316L is the mild steel of stainless materials, 304 is also a mild steel stainless.  Not enough carbon to be properly hardened into a blade.  That said, it could be used in canned Damascus to produce some interesting patterns.  If something with a higher carbon content were used as the cutting edge and the 316 kept to the spine area you could end up with some great looking cutters
On 2/21/2016 at 2:14 AM, metalmangeler said:
Since this is the knife section I guess that is the intent. I might think about using it for bolsters or guards. seems like a nice place for a pattern and would not need to be hard.
My thoughts as well... Plus, 316L is pretty corrosion resistant, making another plus for use in a bolster or guard.
  • 2 weeks later...
