January 28, 201610 yr i am about build a propane froge first one . my question is can i use the regulator off of a acetaline bottle set up or do i have to have the adustable one from a propane supply house i. i can get a regulator from harbor frieght for 35 and a hose for 15
January 28, 201610 yr If the acetylene regulator is rated "for all fuel gasses" then yes; if not then no. If not marked then no.
January 28, 201610 yr Depending on the size of the forge you may be able to get a propane regulator at a hard ware store depending on what part of the country you live in. The adjustable regulators used to boil or turkey fry are often used. Personally I recommend a propane regulator from an Industrial Gas supplier which has a higher volume delivery, better control, and gauges. There are some things I won't buy from harbor freight. Gas welding/cutting equipment is one of them. Too many safety issues connected with their suppliers.
January 29, 201610 yr Excellent summation, Charlotte: To not using Harbor Freight regulators, I would add, not to use Mr Heater regulators, and cheap no brand name regulators. the price difference between the worst and best regulators is between $10 and $20, depending on size; talk about false economy! Also, I recommend regulators designed for LPG over standard torch regulators, because LPG regulators are more resistant to "freezing up" under wet winter conditions.
January 29, 201610 yr You might want to consider one from a company that sells forge making supply's. I am going to be making a gas forge and although it seems expensive, I am going to get a single burner regulator kit from Zoeller forge. Well that is if you are using a single burner. If you need one for two or three or how ever many burners, they sell them too.
January 30, 201610 yr They sell a good regulator at a reasonable price; Fisher brand, if I remember correctly.
