hiltsbilt Posted January 1, 2016 Share Posted January 1, 2016 I made some knifes and sheaths for my nephews for christmas. They are all mostly the same, just different color sheaths and paracord. I had only made 1 knife prior to making these 5 so they are a simple shape but thick and strong for whatever they want to do with them, and have a bushcraftish shape :-) The first picture is after they opened them, then the close ups are of the one I kept for myself. The last few Pics are of a smaller knife that is more suitable for my EDC, I'm not sure I like the shape but its comfortable to hold and works well, I also did not rough cut the shape, just through it in the forge and started hammering. All of the knifes are made of 1095. This was also my first time doing any leather work thats why i used rivets I could not get all the leather tools needed to do stitching. Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 1, 2016 Share Posted January 1, 2016 Your nephew on the left certainly looks like he's ready for whatever's coming! Quote Link to comment Share on other sites More sharing options...
Worshipdrummer Posted January 6, 2016 Share Posted January 6, 2016 I really like the handmade look (hammer marks and stuff) of those blades. Stormcrow, who's work I follow on here, does a similar finish on his blades. Do you mind if I ask you to give a brief run down on how you get the consistent look. Quote Link to comment Share on other sites More sharing options...
hiltsbilt Posted January 8, 2016 Author Share Posted January 8, 2016 on the bigger knifes I cut out the basic shape with an angle grinder then took then to the forge to refine the shape and forge the bevels. then when I annealed the blades I wire brushed them very well to clean them up a bit, after that i did a bet of rough grinding and then hardened and tempered the blades. next I took some 400 gret wet dry sand paper and with some water used it on the whole blade just to clean them up a little and give then the little shiny spots. But I do not smooth and grind the whole blade, only what is going to be sharped, because I like the rustic finish and being able to see the hammer marks looks cool. Quote Link to comment Share on other sites More sharing options...
