December 26, 200718 yr Does anyone have an idea of the actual weight of this hammer? I'm going to be moving three of them in January. Any information would be really helpful. These are going to be the unguided variety. I'm not sure if they are worth getting or not.
December 26, 200718 yr There are two types of Bradley helve hammers, the helve and a guided helve. Rough memory of someone with severe CRS is that the 100# guided helves weigh about 6000#. A great hammer!
December 26, 200718 yr bigjohn go to the top of the forum page and click on User CP Click on Edit profile Go to the bottom of the page and enter your location and save. We would like to know where in the world your located.
December 28, 200718 yr They are heavy and take up a lot of room. I think Skunkriver is about right on the weight I am away from home and can't lay my hands on "Pounding Out The Profits" Bradley's were industrial grade hammers, and had good control. The rubbers are a bit of a pain to replace, but if these were in running condition they are a wonderful find, and if they all need tons of repair and refitting they are still a very good find.... If you find a bigger power hammer... BUild a bigger shop!!! ;-) And when you tell us you are getting paid to haul them away, then we can all be REALLY really jealous... instead of just really jealous;-) Oh and if you can haul them to Quadstate in Troy OH the four weekend in September I am pretty sure it would be worth your while... ;-)
December 28, 200718 yr Hello, I am new to the forum. I have also just acquired two Bradley hammers, one 200 lb. weight 7800 lbs. and a 500lb. weight 18000 lbs. I ran both hammers before the purchase and was very impressed. The 500 didn't have the control I expected, I think the belt was not treated properly. It had been cleaned often with Windex, to get the "gummy" off. It seem you would want it to slip more. Is there a dry powder someone could suggest?
December 28, 200718 yr Dillon, Turn the belt over and try the other side. It's an easy way to check surfaces.
December 31, 200718 yr DD, I have excellent control with my Bradley 300 lb Guided helve. I use a spray on belt dressng, but that should not be necessary to give you better control, it just reduces some of the slipage and gives you a quicker start up since you have so much mass to get moving with on of these hammers. Make sure the belt is tight enough, or that you can make it tight enough. There is an adjustment for the postition of the idler arm and wheel located just in front of the drive wheel on this hammer. You may need to move this so that the idle are puts more tension on the belt when at rest than it does now. On my hammer, the belt will constantaly cycle, even when the hammer is not in motion. Patrick
December 31, 200718 yr Author Well, it sounds as if they may be worth the drive and effort to get the hammers. I may hire a rigger and a lowboy trailer to drag these back to TN. Then I can take all the forges anvils, tongs and other small stuff on my truck. If anyone is interested in the Bradleys, just let me know. I should have all sorts of tools available around mid February.
January 1, 200818 yr Author Well I won't be far off. The site is in PA and i'm delivering a 100lb Little Giant to a friend in CT near Norwalk. If you are on the way I could stop by. That way I only have to drag two of them back. I am still calculating how much Sam Adams equals power hammer. Quite a bit I should think.
January 9, 200818 yr hi John, the 100 guided ram helve wieghs 4700, the 100 upright helve weighs 6650, and the 100 compact wieghs 3500. I have a 125 Guided Ram Helve, and its a beast.
