February 3, 201511 yr Co worker gave me an auger tooth he found. I made a hot cut out of it. My first attempt at forge welding was to get those pegs together and I think it came out pretty good. Tapered the edge, and heat treated in oil. Works good so far, fits better on a diagonal. http://www.iforgeiron.com/gallery/image/38678-hot-cut-hardy-tool-from-auger-tooth-ready-for-action/ http://www.iforgeiron.com/gallery/image/38677-hot-cut-hardy-tool-from-auger-tooth/ I haven't posted much lately but I have been in the process of building a shop. I basically got it built just laying out the inside now. You can kind of see my forge that I just got finished in one of those pics. Just rigged a dimmer switch to the fan this week. One day soon I'll have to post some pics of the forge and my new shop.
February 4, 201511 yr Author Member Kette commented on the pic in my gallery about the hot cut possibly damaging the hardy hole by using it diagonally. Should I try to upset it more at the base and try to make fit the entire hardy better or sit flatter on the anvil? When I insert it in at 90 degrees its just a little too narrow and has alot of slop. I used it, and it cuts just fine and wasn't hard to make, but I dont want to damage my anvil in the long run. Any advice would be appreciated.
February 4, 201511 yr Unless you use the hot cut an incredible amount and hit it very hard, I can't foresee any major problems. Though it may be in your best interest to upset it down so that it will fit properly.
February 4, 201511 yr Adjust it so that the force is transferred to the face of the anvil and not the wedged hole and you are good to go!
February 4, 201511 yr I've read of a smith forging one from spring to fit diaganaly to save weight in his travaling (air) kit. I think it was on here somwhere
February 13, 201511 yr that looks like it will do the trick, if you use it on big stock or alot it may work it self down the hardy alittle bit but it will just make the shoulder a little more defined
