November 10, 201411 yr if your making them yourself I'd be looking hard for some 4340, s7 as a second choce, h-13 if someone was paying you..... a goodly chunk of money. Take care, Matt
November 10, 201411 yr Author Thanks for feedback. The dies is for hammers 15-75 kg . Flat , combi, fullering and crown dies. Im have a company making the dies for me. Here is the durability and quality that counts :) I made some dies myself some years ago of H13, Its hard to machine I must say.
November 18, 201411 yr Have used forklift forks with good result, i know its an unknown but they respond well to an oil hardening, an are common to find in large dimensions.
November 18, 201411 yr Have used forklift forks with good result, i know its an unknown but they respond well to an oil hardening, an are common to find in large dimensions. Were you able to cut them with anything other than a torch? I have a small one and tried horizontal bandsaw, chop saw, plasma cutter. I just didn't want to have to grind off the ugly torch marks along the cut.
November 18, 201411 yr really? I've cut lots of bits of fork lift and I've used my horizontal bandsaw (nice sharp blade helps) and angle grinders before I got the saw.
November 19, 201411 yr I have had really good luck with forklift steel too but you need to aneal it first to cut it with a saw.
November 19, 201411 yr I have had really good luck with forklift steel too but you need to aneal it first to cut it with a saw. That's quite a chicken and egg problem ;-). I can only anneal small pieces. I can only cut annealed pieces. So, in your experience, does it air harden or can you soften it enough by bringing it to heat and then air cooling?
November 20, 201411 yr likewise :) I don't think I have ever annealed a piece? I could't saw close to the place it was gas axed from the main beam, but the rest cuts fine on the bandsaw (slow, but I only have a small saw!)
November 20, 201411 yr i've mostly used mine for anvils, so they have all been heat treated (well the first 1/2" or so of the face certainly). I did make some flypress tooling from a bit and I should've heat treated it, after a few months they got damaged beyond use :(
November 21, 201411 yr S7 works very well for hammer dies. I costs about the same as 4140 and you don't need any quenching medium, as it's air hardening. A 3x3x6" is $79 through Hudson. You can temper with pretty good control in your kitchen oven at 550f and get good results at 55Rc. Perhaps a bit harder than you'd like but it works well for me, as long and the features are not to fine. I don't know why you'd ever use H13 for a hammer die. I can't see the die ever getting to a temperature you'd see deformation with S7 or 4140 / 4340. A great material for true hot work however. There is a great heat treat paper on line on the Tidewater Blacksmith site if you need the information presented in simple easy to follow manner. http://tidewaterblacksmiths.com/heat.html
