JimsShip Posted June 7, 2014 Share Posted June 7, 2014 I have an empty quarter keg and was wondering if I could use it as a shell for a gas forge... It would be lined, do you think it will hold up? Quote Link to comment Share on other sites More sharing options...
Geoff Keyes Posted June 8, 2014 Share Posted June 8, 2014 I don't see why not. Cardboard would work if you lined it properly. Geoff Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 8, 2014 Share Posted June 8, 2014 Sure, even an aluminum keg will work with 2" of Kaowool or equivalent. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
eseemann Posted June 8, 2014 Share Posted June 8, 2014 That reminds me of the time Alton Brown used a cardboard box (2 of them) to make a cold smoker for salmon. Quote Link to comment Share on other sites More sharing options...
Dodge Posted June 9, 2014 Share Posted June 9, 2014 Ask Garey Ford aka garey here. He makes beer keg forges :) Quote Link to comment Share on other sites More sharing options...
JimsShip Posted June 9, 2014 Author Share Posted June 9, 2014 Thanks! I'll drop him a note. I'm glad it would work out, I couldn't find a welder to cut a propane tank, and Frosty gave me the idea to use chimney pipe, but when looking for some, the stuff i found was way pricey, so this may make a nice option. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 9, 2014 Share Posted June 9, 2014 I've seen a gas forge at a professional's shop where he just took a roll of kaowool and put a couple of pieces of binding wire around it and stuck a burner in it when he needed a larger forge to do a specific one time job...The shell is basically to product the innards and cut down on fibers floating in the breeze. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 9, 2014 Share Posted June 9, 2014 I've used hardware cloth to hold the Kaowool in place but more as an example that nothing special is really necessary. Something I've been thinking about to contain the fibers in something like that is high temp paint on the outside. Encapsulating the fibers is all that's really necessary. Think it'll work if not, why not? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
