Avadon Posted May 31, 2014 Author Share Posted May 31, 2014 They aren't that brite. They will sell them for scrap. Copper nails and adhesive. Yah good idea ;) Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 1, 2014 Share Posted June 1, 2014 When doing parts like this die speed is a critical part of the process. Slow-no go. Fast-forms like butter. This part may be able to get by with a single die, and stamping as only the point is getting maximum stretching. Depending on thickness of the annealed stock you are starting with. I would be way more concerned with theft than anything else. With portable power tools like recip saws and the like,tweekers can get through a lot of barriers more easily now. Quote Link to comment Share on other sites More sharing options...
Avadon Posted June 1, 2014 Author Share Posted June 1, 2014 Does anyone know what kind of machinery/equipment I could use at home to make these? Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted June 1, 2014 Share Posted June 1, 2014 I would use the 30 ton hydraulic press I use for forming and bending, it is quiet. it has a 3hp motor. I would try to make them less tall, half the height makes it a lot easier to do Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 3, 2014 Share Posted June 3, 2014 Also forming at a red heat may make things work on a slow press. There is always explosive forming ;) Quote Link to comment Share on other sites More sharing options...
