Black Frog Posted May 22, 2013 Share Posted May 22, 2013 I have a heavy duty roller cart with a 1" steel plate on it that I'd like to mount my forge on. Probably fabricate a pedastal on the side of the cart to raise the forge and keep the table top available and open. I'd like to 'hardwire' my gas forge from the idler valve that will be mounted on the side of the cart up to the forge itself. From the idler vavle to the tank will be the flexible tubing. That will allow me to move the cart in/out a few feet without disconnecting from my 100# tank. Black pipe or copper tubing for propane? Quote Link to comment Share on other sites More sharing options...
Dale M. Posted May 22, 2013 Share Posted May 22, 2013 Copper tubing allows for lots of angle changes and mismeasurements... Black Iron pipe is rigid and does not allow as much 'Flexibility" as to how you route plumbing... Dale Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 22, 2013 Share Posted May 22, 2013 Either is safe and will work just fie. The black pipe has no give so you have to get it right or it won't connect. Frosty The Lucky Quote Link to comment Share on other sites More sharing options...
Black Frog Posted May 22, 2013 Author Share Posted May 22, 2013 Is there a certain type of copper tubing used for propane? Like Type L or K? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted May 22, 2013 Share Posted May 22, 2013 L and K types are wall thickness. your PSI wont be enough to worry which you choose to use. Quote Link to comment Share on other sites More sharing options...
Black Frog Posted May 23, 2013 Author Share Posted May 23, 2013 Or how about the braided stainless flex propane hoses? Quote Link to comment Share on other sites More sharing options...
Dale M. Posted May 23, 2013 Share Posted May 23, 2013 L or K refers to rigid copper pipe for water or waste drain lines (I believe) .... You want soft copper tubing that comes in a coil and use flair fittings.... Dale Quote Link to comment Share on other sites More sharing options...
