Finally finished Maker's Mark
Dear Lodestone,
Just a suggestion: If you make a Mark II version I would suggest some design element suggesting magnetism or north seeking, a North Arrow perhaps or magnetic field lines or the pole star or some combination of such or similar elements. Everybody and their dog uses an anvil as a design element.
Also, what is a "CNC?" Some sort of milling machine or cutter?
Suggestively,
George M.
Thanks for the input George! I'll keep that in mind as i move forward.
A CNC is a computer controlled milling machine. He has one that you just load your computer model into and it mills out whatever you designed into whatever material you want. (within reason, and as long as you use the right type of bits for the material.)
