territorialmillworks Posted October 25, 2012 Share Posted October 25, 2012 I'm re-purposing some hardware that was copper plated and covered with a black lacquer type material to 'antique' it. Sanding is impractical/incomplete and burning it in the forge accomplished nothing. (All PPE/safety procedures were observed :D ) Muriatic acid after removing the the lacquer/varnish didn't help. Any suggestions??? THX, Keith Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted October 26, 2012 Share Posted October 26, 2012 You might try heating to red in the forge and then power brushing with a wire cup brush. That ought to clean up most any surface alloys or platings. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 26, 2012 Share Posted October 26, 2012 un-electroplate it? Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 26, 2012 Share Posted October 26, 2012 I have found that cup brushes work best on flat surfaces. A non-cup wire brush works better for non-flat surfaces. What ever you use, a slow RPM is recommended and clamp or hold the work piece VERY securely. Be sure all safety guards are in place and use all the personal protective equipment, such as safety glasses, full face shields, lather apron, etc. I know of one smith that was using a wire brush on the end of a motor to clean up a 3/8 inch square S hook, The wire brush grabbed the hook from his hands and threw it back at him breaking his safety glasses and giving him both a head trauma and concussion. Quote Link to comment Share on other sites More sharing options...
newbieforge Posted October 26, 2012 Share Posted October 26, 2012 You might try something like this: http://www.rona.ca/en/stripper---paint-stripper-0776170--1 I've had good success with products like it (methylene chloride solvents) to take off all kinds of old paint and varnishes from metal parts. Just a few minutes after you lather that stuff on, the old paint will start to bubble up and separate. For tough paint (e.g. paint that may now be baked on... :) ) you could leave it for a few hours, or over night. The old paint should come off with hand scraping and brushing. If everything doesn't come off in the first shot, give it a second "bath". Prior to leaning about this paint stripping chemical, I made a huge mess in my garage by using a belt sander and wire cup brush to strip paint off an old propane cylinder, which eventually became my gas forge. Needless to say, these days I get everything off that I can using chemical methods, before resorting to brute force mechanical methods. Markus Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 26, 2012 Share Posted October 26, 2012 Tumbling it will take it all off. Methyline Chloride will take paint off for sure but be sure to use a proper filter mask or ventilation, it isn't good to breath. It isn't sudden death or instant cancer but it sure isn't good for you. Yeah, we used a lot in the asphalt lab for extractions. We used Trichorethylene and trichlorethane too, not instant death but nasty. Just be careful and use common sense please. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
newbieforge Posted October 27, 2012 Share Posted October 27, 2012 Solid advice, Frosty. I always set up good ventilation (open windows or open doors, and an oscillating fan or two) when working with chemicals. Markus Quote Link to comment Share on other sites More sharing options...
