PaulKrzysz Posted October 24, 2012 Share Posted October 24, 2012 I have a anvil with many chisel marks on the face. Most are not over 1/32'' deep. I would like to know what methods anyone would recommend to smooth the face down. Belt sander? Angle Grinder? Or are you feeling cynical and want me to file it? Thank you! Quote Link to comment Share on other sites More sharing options...
wd&mlteach Posted October 24, 2012 Share Posted October 24, 2012 If they are not too deep as you are suggesting I would use a belt sander. I would also search this out as others have asked this question before. If I were cynical I would have suggested a leather strop. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 24, 2012 Share Posted October 24, 2012 First of all is their enough face thickness not to worry about losing some of it? If so a belt sander should do it and you do NOT want to grind all the way through every dent! Just clean it up a bit. The old large anvils tended to have softer faces due to auto tempering and slower quenches and so often show more dings. Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted October 25, 2012 Share Posted October 25, 2012 My large anvil was in a little worse shape than yours. I spent about 8 hours with a friend preheating, welding, grinding etc. to rebuild the face. You need to follow the correct methodology with the right rods to get acceptable results. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 25, 2012 Share Posted October 25, 2012 Try it and see if they transfer to your work. I suspect they will not affect hot work. Phil Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted October 25, 2012 Share Posted October 25, 2012 Before you use a grinder take a small ball pein and work around each mark carefully and the dings may close up. Then a flatter hammer for more of the same..i suspect the anvil will work out fine if youi do this and not need anything more aggressive. Quote Link to comment Share on other sites More sharing options...
Old N Rusty Posted October 25, 2012 Share Posted October 25, 2012 I had an idiot drive a chisel into the face of my mousehole anvil. The dings closed up nicely with a lot of ball peen hammering and T.I.G. welded 1/16" E 70-S2 mild steel . Weld with very low amperage , peen each tiny pass. Do not build up a bump, just fill cracks. I would not use a grinder at all on the anvil . A belt sander or sandpaper flap discs should be all you need to finish it . Quote Link to comment Share on other sites More sharing options...
murfcabbage Posted October 26, 2012 Share Posted October 26, 2012 I went the hard way and it worked real good. I took a file to my fisher which had a dinged up face. The file stays flat on the face and I just elbow greased the bugger. After maybe 10-30 minute sessions, the face came out really nice, no heat build-up, no over grinding. The beauty of the file is that you will not overdo it. Major arm work though. Quote Link to comment Share on other sites More sharing options...
macbruce Posted October 26, 2012 Share Posted October 26, 2012 #36 grit cup wheel held FLAT in swirling motions across the whole face, then on to Finer grit flap discs flat across the whole face. The dissapearing marks are a good indicator of how even your progress is. I wouldn't try to get all the marks on that one, works for me......... Quote Link to comment Share on other sites More sharing options...
PaulKrzysz Posted November 5, 2012 Author Share Posted November 5, 2012 I put a little work into it this weekend. I used a angle grinder with a cutting disk, then a belt sander, and finished it by hand.http://s1137.beta.photobucket.com/user/Paulky/media/kk162.jpg.html?sort=3&o=0 If someone can tell me how to put decent sized pictures in my post I would appreciate it. If i upload then directly they are always too big. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted November 5, 2012 Share Posted November 5, 2012 You need to resize your images. 800x600 is a good size. Under "More reply options" next to the "post" button is the stuff for attaching images. I use GIMP for resizing. There are more lightweight programs out there though. Phil Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted November 5, 2012 Share Posted November 5, 2012 Phil is right however that is over simplified. Think in steps. Get a program that will allow you to import pics and re-size them. Here it may seem very complicated..but ...when re-sizing a picture most programs are thinking in inches. Generally right there beside the options area you chose pixels instead of inches or dots per inch. Most here will choose 400 or 600 or 800 pixels in the horizontal choice. That makes a decent size picture that is easy to upload or download or look at. Good luck with your very nice anvil. Carry on Quote Link to comment Share on other sites More sharing options...
pkrankow Posted November 5, 2012 Share Posted November 5, 2012 delete Quote Link to comment Share on other sites More sharing options...
