Azur Jahić Posted September 30, 2012 Share Posted September 30, 2012 so guys i find this material it was old fuirninture and i want to make box bellows with it i relaiser if i make bigger bellows waisting air in small hole wood"nt be important so i asking you how to make bellows to not ruin this material ;I need that this work Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 30, 2012 Share Posted September 30, 2012 Make a sample from cardboard first. Then use the cardboard to transfer dimensions to the wood. Keep in mind the difference in thickness between cardboard and the wood Quote Link to comment Share on other sites More sharing options...
781 Posted September 30, 2012 Share Posted September 30, 2012 At SOFA last week I bought a box bellows I will try to take some lifts. It is double acting meaning it gives air on the push and pull. The plunged seal is made with feathers Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 30, 2012 Author Share Posted September 30, 2012 do you have a pictures can you show Quote Link to comment Share on other sites More sharing options...
rsw Posted October 1, 2012 Share Posted October 1, 2012 http://www.manaraefan.co.uk/index_files/Page408.htm Does this help any? Quote Link to comment Share on other sites More sharing options...
mat Posted October 1, 2012 Share Posted October 1, 2012 great link rsw thanks for that. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 1, 2012 Author Share Posted October 1, 2012 how obaut dimenssion of box bellows ? Quote Link to comment Share on other sites More sharing options...
jeremy k Posted October 1, 2012 Share Posted October 1, 2012 Azur - click on the first link then click on the photos for more photos - dimensions are all there. http://www.katanabuilders.com/katanablog/fuigo-box-bellows/ This link has the descriptions of building with more photos and with photos of building a forge that this box bellows is used with. http://www.razoreye.net/mirror/charcoal-making/Box%20Bellows.htm If this does not help you - please do some more searching yourself on the net... Search "building a box bellows" Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 1, 2012 Author Share Posted October 1, 2012 http://www.google.ba...29,r:0,s:0,i:64 i see this firs on my life how this water bellows work can i make it wiith small or i must use big galoon drums Quote Link to comment Share on other sites More sharing options...
jeremy k Posted October 1, 2012 Share Posted October 1, 2012 Azur - I forgot to put up the other link in the post before your last post - I have got both links in that post now (post#8). Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 1, 2012 Author Share Posted October 1, 2012 thank you i will se what i can get with my material and by the way is the dimensions in milimeters Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 2, 2012 Share Posted October 2, 2012 The water drum bellows is described in Harries and Heers "Basic Blacksmithing" about page 113 you can download a pdf here...well, I can at least...I don't know how well it will work in your part of the world.http://www.webpal.or...ods/pioneer.htm Any type of valve will require neat accurate cutting. Is there a friend of yours with some carpentry skills who can help? Phil Quote Link to comment Share on other sites More sharing options...
mat Posted October 2, 2012 Share Posted October 2, 2012 Azur check this out Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 2, 2012 Author Share Posted October 2, 2012 is this draw in inches or milimeter?kutija.bmp Quote Link to comment Share on other sites More sharing options...
Jeff Lodge Posted October 2, 2012 Share Posted October 2, 2012 is this draw in inches or milimeter? Looking at the file that's posted I would assume the measurements are metric. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 2, 2012 Author Share Posted October 2, 2012 can i use two bucket for water bellows i test it on small bellows it work good can i try with bucket about 10 liters Quote Link to comment Share on other sites More sharing options...
jeremy k Posted October 2, 2012 Share Posted October 2, 2012 Azur - people have given you direction - try it and let us know Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 3, 2012 Author Share Posted October 3, 2012 i make some bellows becazse i dont have leather i use a inner tube i dontknow is that good idea but here is picture Quote Link to comment Share on other sites More sharing options...
blacksmithingone Posted October 4, 2012 Share Posted October 4, 2012 Azur if it works then that is all that matters. it may not be the best material to use but try it and see what happens. that is what this is all about. you may have great success with that material and you may not but so what. it is part of this adventure you are on. if it works or dont then just reply back and tell us what happened. we can all give you advice but unless you are willing to try it out then it really doesn't matter. there is nothing wrong with asking questions but you have to be willing to accept the suggestions or even try them. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 4, 2012 Author Share Posted October 4, 2012 i said that i try with inner tube and dosent work i will try again with trapaulin or awning i will see what i get buy Quote Link to comment Share on other sites More sharing options...
